JFFS2 + S29GLXXXN... Flashdisk?
Sebastian Huber
Thu Jan 9 10:22:30 UTC 2014
On 01/09/2014 11:15 AM, Nick Withers wrote:
> On Thu, 2014-01-09 at 11:09 +0100, Sebastian Huber wrote:
>> Hello Nick,
>> you can find the JFFS2 documentation here:
>> http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__JFFS2.html
> Thanks Sebastian,
> 'Fraid I'd seen that though.
> ...And I need to provide callback functions to actually drive the
> hardware.
>> Please ask (or send patches) if the documentation is insufficient.
>> Maybe we should add some glue code to be able to use existing flash disk
>> drivers. Our customer has its own low-level flash driver so I had no
>> budget to deal with this.
> So I can't just use the Flashdisk driver, then? I'd need to implement my
> own interface to the hardware (which can be done)?
You can probably use the flashdisk driver to implement the JFFS2 callbacks.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
