rtems 4.11 toolchains compiling problem
Fri Jan 17 01:52:47 UTC 2014
You appear to be using some old versions of the RTEMS tools. You
should get updated tools to build the current git master. You might
find pre-built tools somewhere, or you may like to the RTEMS Source
Builder.
-Gedare
On Thu, Jan 16, 2014 at 8:46 PM, 张振兴 <harbor0727 at gmail.com> wrote:
> There was a problem as follow when I compiled rtmes-4.10.99 by rtems 4.11
> toolchains. why? thanks!
> /opt/rtems-4.11/lib/gcc/i386-rtems4.11/4.7.2/../../../../i386-rtems4.11/lib/libc.a(lib_a-wcrtomb.o):
> In function `_wcrtomb_r':
> /build/ralfcorsepius-rtems-4.11-i386-rtems4.11-gcc_4.7.2-0precise3-amd64-P7YbYw/rtems-4.11-i386-rtems4.11-gcc-4.7.2/build/i386-rtems4.11/newlib/libc/stdlib/../../../../../newlib/libc/stdlib/wcrtomb.c:15:
> undefined reference to `__stack_chk_guard'
> /build/ralfcorsepius-rtems-4.11-i386-rtems4.11-gcc_4.7.2-0precise3-amd64-P7YbYw/rtems-4.11-i386-rtems4.11-gcc-4.7.2/build/i386-rtems4.11/newlib/libc/stdlib/../../../../../newlib/libc/stdlib/wcrtomb.c:40:
> undefined reference to `__stack_chk_fail'
> In function `wcrtomb':
> /build/ralfcorsepius-rtems-4.11-i386-rtems4.11-gcc_4.7.2-0precise3-amd64-P7YbYw/rtems-4.11-i386-rtems4.11-gcc-4.7.2/build/i386-rtems4.11/newlib/libc/stdlib/../../../../../newlib/libc/stdlib/wcrtomb.c:48:
> /build/ralfcorsepius-rtems-4.11-i386-rtems4.11-gcc_4.7.2-0precise3-amd64-P7YbYw/rtems-4.11-i386-rtems4.11-gcc-4.7.2/build/i386-rtems4.11/newlib/libc/stdlib/../../../../../newlib/libc/stdlib/wcrtomb.c:77:
> collect2: error: ld returned 1 exit status
> make[6]: *** [hello.exe] Error 1
> make[6]: Leaving directory
> `/home/zhangzhenxing/rtems/build_rtems_99/i386-rtems4.11/c/pc386/testsuites/samples/hello'
> make[5]: *** [all-recursive] Error 1
> make[5]: Leaving directory
> `/home/zhangzhenxing/rtems/build_rtems_99/i386-rtems4.11/c/pc386/testsuites/samples'
> make[4]: *** [all] Error 2
> make[4]: Leaving directory
> make[3]: *** [all-recursive] Error 1
> make[3]: Leaving directory
> `/home/zhangzhenxing/rtems/build_rtems_99/i386-rtems4.11/c/pc386/testsuites'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> `/home/zhangzhenxing/rtems/build_rtems_99/i386-rtems4.11/c/pc386'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> `/home/zhangzhenxing/rtems/build_rtems_99/i386-rtems4.11/c'
> make: *** [all-recursive] Error 1
> rtems-users mailing list
> rtems-users at rtems.org
