MVME5500 1 Gbit Ethernet no longer works
Kate Feng kate007.feng at gmail.com
Fri Jan 17 04:44:32 UTC 2014
     In USA, the original version of mvme5500 is still available for
purchasing.
I was in the process of adding the software support for the new NIC on
the mvme5500 board, then here is the discussion.....
      According to the manufacture specification of the Discovery
system controllers (i.e. controllers for mvme5500 and mvme6100),
 "GPP interrupt value register" should be used to monitor the interrupts.
However,  Beatnik BSP uses the "GPP interrupt cause register" to
monitor the interrupts. I started to write a disco BSP to add supports
for discovery based boards such as mvme6100 to be run-time
compatible with the mvme5500 BSP that I wrote.
1) I prefer to follow the manufacture's specification.
2) I read the code of the beatnik network drivers years ago.
The code for the 100 MHz NIC on mvme5500 and 1 GHz NIC
on mvme6100 was patched with workarounds.  If I recall
correctly, I tested the network performance of the beatnik BSP on the
100 MHz NIC on an image processing application, it delivered only
50% of performance as compared with that of the mvme5500 BSP.
I do not recall if I tested the performance of beatnik BSP on mvme6100.
With the assigned tasks I had back then,
a) I needed to test the performance, especially that of the DMA,
on the mvme6100 without compromising its performance and the
code (i.e. no workarounds !!! ).
b) It is painless to add supports for other discovery based boards because
I had the mvme5500 BSP handy.
   The mvme5500 BSP supports the operations at NSLS smoothly.  I never
needed to write any workarounds  in my applications, including the code
for DMA. If there were any bug in the applications, I could be so confident
that it was not due to the BSP.  The mvme6100 functions smoothly with the
disco BSP, too.  However, the performance delivered by the mvme5500 BSP
is fast enough for most of my applications.
Cheers,
Kate Feng
On Thu, Jan 16, 2014 at 5:21 PM, Peter Dufault <dufault at hda.com> wrote:
> Till, does SLAC use a mixture of 5500 and 6100 painlessly with Beatnik?
>  I've told my client that uses the MVME5500 with Beatnik to get a 6100
> in-house and test it out with their RTEMS software.  As long as things are
> changing on the MVME5500 (slower cache, different ethernet controller) they
> should evaluate using the 6100 instead (faster processor, two gig-E
> ethernets, etc) to see if that can be used on new systems and as a
> replacement part (with the replacement maybe tied to recent software
> releases, they can hoard the older boards for really old systems).
> On Jan 16, 2014, at 12:04 , Till Straumann <strauman at slac.stanford.edu>
> wrote:
> > FWIW: the driver I ported for the beatnik BSP is almost 10 years old
> > and it seems to support the 82545GM (IDs 0x1026, 0x1027, 0x1028).
> > You could use this BSP or you could also use the driver from the
> > libbsdport addon package (which is newer than the one in beatnik).
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20140116/ee1510e5/attachment-0001.html>
