Including 3rd party library headers?
James Fitzsimons
james.fitzsimons at gmail.com
Tue Jan 28 21:11:53 UTC 2014
Hi Sebastian,
Thanks for your reply.
Ideally I was hoping to us the -I option to specify the header file
location, I just can't quite figure out where to add that into the RTEMS
makefile structure. Looking at the make/README I can see a good example of
how to link in other libraries using LD_LIBS, but there's nothing about
including other header files.
Apologies if I am missing something obvious!
Cheers,
James Fitzsimons
On 28 January 2014 22:31, Sebastian Huber <
> On 2014-01-28 10:24, James Fitzsimons wrote:
>> Is there a suggested way to include header files for third party
>> libraries? At
>> the moment I've had to resort to using the C_INCLUDE_PATH environment
>> variable
>> to get GCC to find the appropriate headers when building my application.
> This question depends on your build system and the way you want to
> organize things.
> You can install the libraries and header files in built-in GCC search
> locations or you can use the -I or -B option pointing to your libraries to
> add more search paths to GCC for example.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20140129/56f0cc6d/attachment-0001.html>
