RES: No configure script in the Git repository?
Fabrício de Novaes Kucinskis
fabricio at dea.inpe.br
Fri Jul 4 14:08:58 UTC 2014
Hi Ezequiel,
Just found this! Thanks for the help anyway!
Regards,
Fabrício.
De: Ezequiel Alfíe [mailto:ealfie at gmail.com]
Enviada em: sexta-feira, 4 de julho de 2014 11:07
Para: Fabrício de Novaes Kucinskis
Cc: users at rtems.org
Assunto: Re: No configure script in the Git repository?
Hello Fabricio:
There's a script called `bootstrap` that creates `configure` and other autotools-related files.
Other projects using autotools use the name `autogen.sh` instead of `bootstrap`.
Regards,
Ezequiel
On Fri, Jul 4, 2014 at 10:56 AM, Fabrício de Novaes Kucinskis <fabricio at dea.inpe.br> wrote:
Hello all,
I'm trying to install RTEMS from the Git repository for the first time - I'm used to get the tar files of the 'stable' releases available at the FTP, but at this time I need to get the newest (4.11).
I got the source files, but when I called the configure script, I found that it is not there. I checked the Getting Started document, and it states no difference on the use of the configure script between sources gotten from the FTP or from Git.
Am I missing something? Is there any additional step I have to perform before calling configure?
Thanks in advance and best regards,
Fabrício.
Este email está limpo de vírus e malwares porque a proteção do avast! Antivírus está ativa.
http://www.avast.com
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140704/ab429d76/attachment-0001.html>
