Application based on Pthreads is blocked under RTEMS
Fri Jul 4 14:12:26 UTC 2014
On 2014-07-04 15:37, smc smc wrote:
> Hi, thanks all for your suggestions.
> @Sebastian: the bsp is MPPA.
Is this an out of tree BSP?  Which architecture does it use?  I am just curious
since SMP is work in progress.
> @Gedare: I cannot send the full code for debugging, because part of it uses an
> proprietary API :/ About your comment, I commit a mistake transcribing the
> code, it is not an assignment operator, it must be '=='.
This was not the only potential error in the sources.  Depending on the
definition of buffer[i].st the compiler may also generate infinite loops as an
optimization.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
