Toolchains for RTEMS on Leon3
Ricardo Derbes
rderbes at invap.com.ar
Fri Jul 4 16:12:17 UTC 2014
Thank you for your answer.
Where can I find the sources for the RCC toolchain? The binaries
available from Gaisler are compiled for 32 bits hosts, and I intend to
work on 64 bits hosts.
Is there any special procedure to build it?
Thank you
Ricardo
On 07/03/14 16:16, Joel Sherrill wrote:
> On Jul 3, 2014 2:01 PM, Jiri Gaisler <jiri at gaisler.se> wrote:
> > On 07/03/2014 07:44 PM, Ricardo Derbes wrote:
> > > Hello.
> > > I need to know wich toolchain can I employ to build applications for
> > > Leon3 multicore processors, on a 64 bits Linux host.
> > If you want to experiment with RTEMS-SMP on leon3, see this post:
> https://groups.yahoo.com/neo/groups/LEON_SPARC/conversations/messages/24058
> > If you want to use RTEMS on Leon3 for production, you can make
> > multi-core, but not SMP applications using the RCC tool-chain from
> > Gaisler:
> > http://www.gaisler.com/index.php/products/operating-systems/rtems
> > You can also build your own RTEMS tool-chain using RSB. See the RTEMS
> > wiki from more details.
> All correct and just a note that SMP support in RTEMS is rapidly
> stabilizing. Testing and feedback from the community is appreciated.
> > Jiri.
> > > Thank you
> > > *Ricardo Derbes*
> > > *Gerencia Aeroespacial y Gobierno*
> > > *INVAP S.E.*
> > > Av. Cmte. Luis Piedrabuena 4950 (ex RN 237)
> > > R8403CPV - San Carlos de Bariloche
> > > Río Negro - Argentina
> > > +54 (294) 4409300 - ext. 1401
> > > www.invap.com.ar
> > > Please consider the environment before printing this email
> > > _______________________________________________
> > > users mailing list
> > > users at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/users
> > users mailing list
> > users at rtems.org
> users mailing list
> users at rtems.org
*Ricardo Derbes*
*INVAP S.E.*
www.invap.com.ar
URL: <http://lists.rtems.org/pipermail/users/attachments/20140704/9c69a32e/attachment.html>
