Debug RTEMS RTL using qemu-system-arm
Mihaela Panescu
mihaela.panescu at gmail.com
Sun Jul 6 17:05:06 UTC 2014
Hi,
Can you try with the following configuration:
#define CONFIGURE_MAXIMUM_POSIX_KEYS 16
#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 16
Mihaela
On Sun, Jul 6, 2014 at 4:21 PM, Peng Fan <van.freenix at gmail.com> wrote:
> I use qemu and gdb to debug, The following is the backtrace. and I found
> that _POSIX_Keys_Allocate() returns NULL/0, is this correct? Any tips? I do
> not know how to debug this, or there should be some shell configuration
> when call rtems_shell_init?
> Breakpoint 1, pthread_key_create (key=0x20b2c8,
> destructor=0x157d55 <rtems_shell_env_free>)
> at
> ../../../../../../rtems-new/c/src/../../cpukit/posix/src/keycreate.c:41
> 41 the_key = _POSIX_Keys_Allocate();
> (gdb) bt
> #0 *pthread_key_create* (key=0x20b2c8,
> at
> #1 0x00157db8 in *rtems_shell_current_env_make_key *()
> at
> ../../../../../../rtems-new/c/src/../../cpukit/libmisc/shell/shell.c:109
> #2 0x0013f2fa in _Once (once_state=0x2071d8
> <rtems_shell_current_env_once+4>,
> init_routine=0x157da1 <rtems_shell_current_env_make_key>)
> at ../../../../../../rtems-new/c/src/../../cpukit/score/src/once.c:42
> #3 0x00136aca in pthread_once (
> once_control=0x2071d4 <rtems_shell_current_env_once>,
> at
> ../../../../../../rtems-new/c/src/../../cpukit/posix/src/pthreadonce.c:39
> #4 0x00158f96 in rtems_shell_main_loop (shell_env_arg=0x5a4118)
> at
> ../../../../../../rtems-new/c/src/../../cpukit/libmisc/shell/shell.c:707
> #5 0x00158f2e in rtems_shell_task (task_argument=5914904)
> at
> ../../../../../../rtems-new/c/src/../../cpukit/libmisc/shell/shell.c:671
> #6 0x0014207c in _Thread_Handler ()
> at
> ../../../../../../rtems-new/c/src/../../cpukit/score/src/threadhandler.c:192
> Backtrace stopped: previous frame identical to this frame (corrupt stack?)
> *(gdb) n*
> *43 if ( !the_key ) {*
> *(gdb) p the_key*
> *$1 = (POSIX_Keys_Control *) 0x0*
> Regards,
> Peng.
> 2014-07-05 15:44 GMT+08:00 Peng Fan <van.freenix at gmail.com>:
> Hi,
>> I encountered a problem when using qemu-system-arm to simulate RTEMS RTL
>> using `qemu-system-arm -no-reboot -net none -nographic -M realview-pbx-a9
>> -m 256M -kernel build/arm-rtems4.11-realview_pbx_a9_qemu/rtld`
>> it continuly outputs the following msg, but not run into a shell prompt:
>> pthread_setspecific(shell_current_env_key)
>> Starting shell....
>> Starting shell....
>> Starting shell....
>> Starting shell....
>> I found that `sc = rtems_shell_init ("fstst", 60 * 1024, 150,
>> "/dev/console", 0, 1, NULL);` returns immediately with the return value
>> RTEMS_SUCCESSFULL.
>> If I `git reset --hard *ffc862cbf567*` to the following RTEMS commit,
>> "commit *ffc862cbf567*068d1cc2b8417bafdf808dfcc67a
>> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
>> Date: Tue Sep 17 13:08:49 2013 +0200
>> bsp/realview-pbx-a9: Add NULL pointer protection
>> Qemu Git version 8641136c54d216edb5bb8ef723c754039b4ce5cf3 or later is
>> required."
>> RTL runs well. I am not familiar with RTEMS internal, not sure why this.
>> The qemu verison is 2.0.0. RTEMS is 4.11.
>> Regards,
>> Peng.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20140706/fb8db395/attachment-0001.html>
