Application based on Pthreads is blocked under RTEMS
Mon Jul 7 06:44:48 UTC 2014
On 2014-07-04 16:35, smc smc wrote:
> Well, MPPA is the name of API and the architecture (manufactured by Kalray), a
> manycore platform with two IO subsystems (running RTEMS). Documentation says
> that the BSP is based on the Oxford BSPlib.
In this case you are probably on the wrong mailing list.  Kalray uses a forked
version of RTEMS.  I guess the SMP in mainline RTEMS and the SMP implementation
used by Kalray have little in common.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
