RAM-DISK / RTEMS4.10 patched with FIX for ramdisk
Rohner Thomas Thomas.Rohner at nanotronic.ch
Fri Jul 11 11:59:37 UTC 2014
Hello,
I'm using RTEMS 4.10 for LEON3 (Gaisler)
I generate my RAMDISK like this
               @dd if=/dev/zero of=$(NAME3) bs=1024 count=4096 > /dev/null
               /sbin/mkfs.vfat -n RD3test -i Ca551509 -F 16 -S 512 -s 1 -r 512 -f 1 -v $(NAME3)
               mcopy -b/ -i $(NAME3) content3/* ::/
               @xxd -i $(NAME3) > $(NAME3).c
               @echo [CC]  $@
               @$(CC) -c $(CFLAGS) -o $@ $(NAME3).c
I mount this as /dev/rdc on mounting point   /mntD3
File functions seemed to work, but I had to do some tests....
... result:  my RAM-Disk is 4MB in 8192 Blocks, 8095 of them may be used -> 8095 * 512 (Blocksize) = 4011008 Bytes. Correct?
I tried to create files (fopen()), write data (e.g. fwrite() 50000 Bytes) until the function fails. I thought that is when Disk is FULL.
But my result is like this:
I can either create   (there are always 185 Files !!!!, even when Disk-space is not used, can't be a limitation of FAT16)
155 Files @ 20'000 Bytes, and 30 files with less than 500 Bytes:  Total amount  3'237'162 Bytes      (this could be correct)
or
155 Files @ 50'000 Bytes, and 30 files with less than 500 Bytes:  Total amount  7'887'162 Bytes      (this is more than 4MB)
or
155 Files @ 100'000 Bytes, and 30 files with less than 500 Bytes:  Total amount  15'637'162 Bytes      (this is more than 4MB)
or
155 Files @ 200'000 Bytes, and 30 files with less than 500 Bytes:  Total amount  31'137'162 Bytes      (this is more than 4MB)
or
155 Files @ 500'000 Bytes, and 30 files with less than 500 Bytes:  Total amount  77'637'162 Bytes      (this is more than 4MB)
After creation of the file and read out the directory, I can delete/remove the files without problem, and RAM-DISK seems work correct.
I think that file-systems are not very secure to use in that case.
Who has already experiences using file-systems, especially when fail-safe is recommended.
Questions:
1.      Is me generation of RAM-Disk correct?
2.      Why can I create not more than 185 files?
3.      Why can I create/use more space than RAM-Disk is generated for?
Thanks a lot in advance for any informations.
Freundliche Grüsse / Kind regards,
Thomas Rohner
Entwicklungsingenieur Software
nanoTRONIC GmbH
Werkstrasse 27, CH - 3250 Lyss
T: +41 32 384 69 30, F: +41 32 384 69 31
www.nanotronic.ch <http://www.nanotronic.ch/>  | thomas.rohner at nanotronic.ch <mailto:thomas.rohner at nanotronic.ch>
URL: <http://lists.rtems.org/pipermail/users/attachments/20140711/1fa894ff/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.rtems.org/pipermail/users/attachments/20140711/1fa894ff/attachment-0001.jpg>
