Phytec MPC5554 not running out of flash?
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Fri Jul 11 15:00:33 UTC 2014
Peter,
just a hint: you are aware that the MPC5554 BAM code expects certain
magics at the start of the flash, otherwise the flash block is
considered non-bootable.
wkr,
Thomas.
Am 11.07.2014 14:44, schrieb Peter Dufault:
> I've been developing code just fine running in SRAM with the current head. I just tried to run out of flash. My software put the program in flash just fine, but it doesn't run, it winds up in the BAM code trying to boot off the serial port / CAN.
> The difference between SRAM and FLASH is only the setup of the MMU, and it's the same code in both cases. For SRAM flash is moved from 0 up to 21400000 and 4MB of SRAM down from 21400000 to 0. The MMU is setup in the debugger and at startup the MMU setup is skipped if a flag in low memory is clear. That's the only difference in the behavior (see below), and I've never noted any differences before.
> I verified that I have the same MMU setup except for the address translation in both situations. It was different, someone changed the setup to only set the supervisor mappings and not map certain sections executable but that didn't matter, I've duplicated those settings and it works the same way.
> Before I go too far can anyone (Sebastian) think of changes in any other places that might affect this?
> static BSP_START_TEXT_SECTION void mpc55xx_start_mmu(void)
> #ifdef MPC55XX_BOOTFLAGS
> /* If the low bit of bootflag 0 is clear don't change the MMU. */
> bool do_mmu_config = (mpc55xx_bootflag_0 [0] & 1) != 0;
> #else
> bool do_mmu_config = true;
> #endif
> if (do_mmu_config) {
> mpc55xx_start_mmu_apply_config(
> &mpc55xx_start_config_mmu [0],
> mpc55xx_start_config_mmu_count [0]
> Peter
> Peter Dufault
> HD Associates, Inc. Software and System Engineering
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Thomas Doerfler
Dornierstr. 4
D-82178 Puchheim
Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18 94 741-12
Fax: +49-89-18 94 741-09
PGP: Public key available on request.
