Interacting with the linker scripts in the STM32F4 BSP
Mr. Andrei Chichak
groups at chichak.ca
Mon Jul 14 22:53:03 UTC 2014
I have a block of parameters that I want to place in FLASH memory at a known location, say the last block of FLASH so that I can read and write it later. (these processors don’t have EEPROM but you can use a page of FLASH as an adequate replacement for internal configuration parameter storage at the cost of halting the bus until the writes complete)
It needs to be on a page boundary, because the FLASH is erased in 2K pages.
Since gcc doesn’t allow syntax like:
static volatile const PARAM_T fu @ 0x000FF800;
static volatile const PARAM_T fu __attribute__((at(0x000FF800)))
or
static volatile const PARAM_T fu __at__ 0x000FF800
I have to use the linker script to push the structure to the target location. The STM32F4 BSP has a set of scripts but there is a lot of existing thought that I don’t want to violate.
Is it possible to add a project specific linker script so that I can place a struct at a particular FLASH location without triggering the .unexpected_sections portion of linkcmds.base? I’ve tried a few things, but the trick escapes me.
Thanks,
Andrei
Typical lame attempt:
typedef struct {
uint8_t filler[2048];
} PARAM_PAGE_T;
static volatile PARAM_PAGE_T flashParamsPage __attribute__((section(".params"))) ;
MEMORY {
PARAM_INT : ORIGIN = 0x000FF800, LENGTH = 2k
SECTIONS {
.params : {
*(.params)
} > PARAM_INT
URL: <http://lists.rtems.org/pipermail/users/attachments/20140714/d1982bab/attachment.html>
