Software flow control for /dev/console on Zynq
Stephen Tether
tether at slac.stanford.edu
Wed Jul 16 21:53:09 UTC 2014
Is there any way to turn on software flow control for /dev/console on
the Xilinx Zynq? Some of my colleagues have noticed dropped characters
when pasting shell command sequences into the minicom window on the
development host. Hardware flow control isn't available on our custom
Zynq board since the required lines are not connected to the FTDI chip
that sits between the UART and USB. I've tried the following under RTEMS
which doesn't seem to work:
char const devname[] = "/dev/console";
int const fd = open(devname, O_RDWR);
struct termios terminfo;
int status = tcgetattr(fd, &terminfo);
if (status) {
printf("First tcgetattr() failed.\n%s\n", strerror(errno));
return;
terminfo.c_iflag |= (IXON | IXOFF);
status = tcsetattr(fd, TCSANOW, &terminfo);
if (status) {
printf("tcsetattr() failed.\n%s\n", strerror(errno));
return;
terminfo.c_iflag = 0;
if (status) {
printf("Second tcgetattr() failed.\n%s\n", strerror(errno));
return;
All the termios calls succeed and the results of the second tcgetattr()
show IXON and IXOFF set, yet the problem persists. On the development
host side I've run a small program that writes a few hundred characters
to the USB tty while reading what comes back in raw mode with IXON and
IXOFF turned off; nary an XOFF character has it received.
So, is there something I'm missing or do I have to implement flow
control myself?
- Steve Tether
SLAC
