Application based on Pthreads is blocked under RTEMS
Joel Sherrill Joel.Sherrill at OARcorp.com
Wed Jul 2 11:37:10 UTC 2014
Also the default attributes for pthreads is different under Linux than RTEMS. This can easily break an application that is depending on the defaults for the objects without realizing it.
On Jul 2, 2014 5:43 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
Hello,
it helps if you send a self contained example.  Which BSP do you use.  You
should consider to use POSIX condition variables instead of the busy wait loops.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140702/71771e0d/attachment-0002.html>
