Application based on Pthreads is blocked under RTEMS
smc smc
smc101979 at gmail.com
Fri Jul 4 14:23:39 UTC 2014
Hi Joel, I have not set special attributes on the pthreads. I set NULL on
second parameter of pthread_create(). However, I did some experiments
changing the scheduling policy and priorities, but the result was similar.
2014-07-04 15:07 GMT+01:00 Joel Sherrill <Joel.Sherrill at oarcorp.com>:
> On Jul 4, 2014 8:33 AM, smc smc <smc101979 at gmail.com> wrote:
> > Hi, thanks all for your suggestions.
> > @Sebastian: the bsp is MPPA.
> > @Gedare: I cannot send the full code for debugging, because part of it
> uses an proprietary API :/ About your comment, I commit a mistake
> transcribing the code, it is not an assignment operator, it must be '=='.
> You should be able to produce a generic version that bus smaller and
> reproduces the problem.
> You did not answer if you have default attributes on the pthreads and
> other objects. They are undefined by POSIX and differ between RTEMS and
> Linux.
> Also a thread spinning in a loop at the highest priority in RTEMS will do
> that forever. My impression is that is what your init thread is doing.
> > Anyway, I am trying to use condition variables, despite of loosing some
> of performance.
> > Regards.
> > 2014-07-03 2:37 GMT+01:00 Gedare Bloom <gedare at rtems.org>:
> >> I'll make one note below, but you should submit the entire
> >> self-contained example that shows the incorrect behavior if you want
> >> debugging help.
> >> On Wed, Jul 2, 2014 at 6:23 AM, smc smc <smc101979 at gmail.com> wrote:
> >> > Hi, I am new in RTEMS. I can't understand why the following threaded
> >> > application is not running on RTEMS as expected. Basically, it
> creates two
> >> > pthreads. One fills a buffer and the other one get an slice and
> submit it to
> >> > a cluster for processing (typical producer-consumer problem),
> something
> >> > like:
> >> > void thread1()
> >> > while(1)
> >> > for (i=0; i < size;i++)
> >> > if (buffer[i].st == -1)
> >> > pthread_mutex_lock(&mutex);
> >> > genData(buffer[i]);
> >> > buffer[i].st=0; // ready to be consumed
> >> > pthread_mutex_unlock(&mutex);
> >> > void thread2()
> >> > while(1)
> >> > // n stores the slice start
> >> > ready = false;
> >> > while (!ready) // it gets a free slice
> >> > ready = true;
> >> > for(i=n;i<n+slice;i++)
> >> > if (buffer[i].st = -1)
> >> If you have this statement with an assignment operator, the
> >> while(!ready) loop should never terminate if slice > 0.
> >> > ready = false;
> >> > // process the slice on cluster
> >> > for (i=n;i<n+slice;i++)
> >> > buffer[i].st = -1; // now new data can be inserted on it
> >> > It runs fine on a Linux/GNU system, but not in RTEMS. Under some
> >> > circumstances the program is blocked. It is like if thread2 was
> running
> >> > forever on the second while, and thread1 didn't fill the buffer. Do
> you have
> >> > any idea of what is happening? I would expect that each thread would
> run on
> >> > parallel on each core.
> >> > Thanks.
> >> > _______________________________________________
> >> > users mailing list
> >> > users at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140704/9d2daf6d/attachment-0002.html>
