Application based on Pthreads is blocked under RTEMS
smc smc
smc101979 at gmail.com
Fri Jul 4 14:35:42 UTC 2014
Hi Sebastian,
Well, MPPA is the name of API and the architecture (manufactured by
Kalray), a manycore platform with two IO subsystems (running RTEMS).
Documentation says that the BSP is based on the Oxford BSPlib.
BOH, buf[i] is an C struct array.
Regards.
2014-07-04 15:12 GMT+01:00 Sebastian Huber <
sebastian.huber at embedded-brains.de>:
> On 2014-07-04 15:37, smc smc wrote:
>> Hi, thanks all for your suggestions.
>> @Sebastian: the bsp is MPPA.
> Is this an out of tree BSP? Which architecture does it use? I am just
> curious since SMP is work in progress.
> @Gedare: I cannot send the full code for debugging, because part of it
>> uses an
>> proprietary API :/ About your comment, I commit a mistake transcribing the
>> code, it is not an assignment operator, it must be '=='.
> This was not the only potential error in the sources. Depending on the
> definition of buffer[i].st the compiler may also generate infinite loops as
> an optimization.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20140704/5df788f1/attachment-0002.html>
