Phytec MPC5554 not running out of flash?
Peter Dufault
dufault at hda.com
Mon Jul 14 07:51:35 UTC 2014
Last November is the last time I'm sure I ran out of flash. I almost never run out of flash, I specifically get them with 8MB of memory to have the 4MB RAM for development. I happen to be working with a new board so it doesn't have the bootstrap code to boot off NFS or I might not have noticed now. And I guess I should first check with a different board just in case.
The other thing that could cause it is the EBI (external bus interface) setup. Since that must be set up by the debugger to download the code to the RAM even though it's the same code running RAM or flash the preliminary setup could let it work (the reset will reset the EBI).
Given the minor differences (same image running code or flash, just skip MMU setup) I think it must be in the BSP and not general code. I'll try to track it down today.
On Jul 12, 2014, at 09:39 , Joel Sherrill <Joel.Sherrill at oarcorp.com> wrote:
> Unfortunately, I suspect that it may be an unintended consequence of changing some shared infrastructure code. I don't recall any changes specifically to this BSP.
> How old is the version that worked?
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
URL: <http://lists.rtems.org/pipermail/users/attachments/20140714/9f22935d/attachment-0002.html>
