Error when compiling for Stellaris LM3S6965
Martin Galvan
omgalvan.86 at gmail.com
Wed Jun 4 18:41:55 UTC 2014
Hi everyone! I'm having a problem when trying to cross-compile RTEMS for a
Stellaris LM3S6965 board. I checked out HEAD using
git clone git://git.rtems.org/rtems.git
and built the toolchain using the RTEMS Source Builder, after which I ran
the bootstrap script and did the following:
$../rtems/configure --target=arm-rtems4.11 --enable-rtemsbsp=lm3s6965
--enable-tests=samples --enable-posix
$ make
However, after a while the compilation stops with the following error:
/home/martin/tools/lib/gcc/arm-rtems4.11/4.8.2/../../../../arm-rtems4.11/bin/ld:
pppd.exe section `.rodata' will not fit in region `ROM_INT'
region `ROM_INT' overflowed by 45932 bytes
collect2: error: ld returned 1 exit status
make[6]: *** [pppd.exe] Error 1
make[6]: Leaving directory
`/home/martin/tools/stellaris/arm-rtems4.11/c/lm3s6965/testsuites/samples/pppd'
make[5]: *** [all-local] Error 1
make[5]: Leaving directory
`/home/martin/tools/stellaris/arm-rtems4.11/c/lm3s6965/testsuites/samples'
make[4]: *** [all] Error 2
make[4]: Leaving directory
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory
`/home/martin/tools/stellaris/arm-rtems4.11/c/lm3s6965/testsuites'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory
`/home/martin/tools/stellaris/arm-rtems4.11/c/lm3s6965'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/martin/tools/stellaris/arm-rtems4.11/c'
make: *** [all-recursive] Error 1
Did anyone else have the same error? I don't recall tampering with anything
so I don't know what could be causing it.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140604/4202eabc/attachment.html>
