Error when compiling for Stellaris LM3S6965
Wed Jun 4 20:05:03 UTC 2014
On Wed, Jun 4, 2014 at 3:57 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com> wrote:
> On Jun 4, 2014 1:44 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> Hi Martin,
>> On Wed, Jun 4, 2014 at 2:41 PM, Martin Galvan <omgalvan.86 at gmail.com>
>> wrote:
>> > Hi everyone! I'm having a problem when trying to cross-compile RTEMS for
>> > a
>> > Stellaris LM3S6965 board. I checked out HEAD using
>> > git clone git://git.rtems.org/rtems.git
>> > and built the toolchain using the RTEMS Source Builder, after which I
>> > ran
>> > the bootstrap script and did the following:
>> > $../rtems/configure --target=arm-rtems4.11 --enable-rtemsbsp=lm3s6965
>> > --enable-tests=samples --enable-posix
>> > $ make
>> > However, after a while the compilation stops with the following error:
>> > /home/martin/tools/lib/gcc/arm-rtems4.11/4.8.2/../../../../arm-rtems4.11/bin/ld:
>> > pppd.exe section `.rodata' will not fit in region `ROM_INT'
>> > region `ROM_INT' overflowed by 45932 bytes
>> > collect2: error: ld returned 1 exit status
>> This error indicates that pppd is too big when compiled for it to fit
>> in the memory image of the board.
> This should have been addressed when Chris added the .tcfg files in various
> BSPs make/custom directory.
pppd only appears in the tcfg for mcf52235
Martin, if you add pppd on a line to the file at
./c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s6965-testsuite.tcfg
then it should skip building that sample.
-Gedare
> Have you rebased recently?
>> > make[6]: *** [pppd.exe] Error 1
>> > make[6]: Leaving directory
>> > `/home/martin/tools/stellaris/arm-rtems4.11/c/lm3s6965/testsuites/samples/pppd'
>> > make[5]: *** [all-local] Error 1
>> > make[5]: Leaving directory
>> > `/home/martin/tools/stellaris/arm-rtems4.11/c/lm3s6965/testsuites/samples'
>> > make[4]: *** [all] Error 2
>> > make[4]: Leaving directory
>> > make[3]: *** [all-recursive] Error 1
>> > make[3]: Leaving directory
>> > `/home/martin/tools/stellaris/arm-rtems4.11/c/lm3s6965/testsuites'
>> > make[2]: *** [all-recursive] Error 1
>> > make[2]: Leaving directory
>> > `/home/martin/tools/stellaris/arm-rtems4.11/c/lm3s6965'
>> > make[1]: *** [all-recursive] Error 1
>> > make[1]: Leaving directory
>> > `/home/martin/tools/stellaris/arm-rtems4.11/c'
>> > make: *** [all-recursive] Error 1
>> > Did anyone else have the same error? I don't recall tampering with
>> > anything
>> > so I don't know what could be causing it.
>> > _______________________________________________
>> > rtems-users mailing list
>> > rtems-users at rtems.org
>> > http://www.rtems.org/mailman/listinfo/rtems-users
