Issues stitching in a BSP on latest MacOS
Fri Jun 13 22:26:42 UTC 2014
On 14/06/2014 8:39 am, Mr. Andrei Chichak wrote:
> On 2014-June-12, at 7:41 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> The automake version is newer than what we have been using. This could
>> be the problem. You may like to use RSB to build your autotools for
>> RTEMS and install them to a path that you use while bootstrap/build
>> RTEMS.
> There was definitely a new version of automaker and autoconf that were getting in the way. I munged my .bash_profile file to make sure that the RTEMS tools took precidence over the tools from macports. That cleaned up the problems with autoconf.
I avoid all external packing systems on MacOS and this is how I test the
RSB tools.
