Issues stitching in a BSP on latest MacOS
Mr. Andrei Chichak groups at chichak.ca
Fri Jun 13 22:43:29 UTC 2014
On 2014-June-13, at 4:26 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 14/06/2014 8:39 am, Mr. Andrei Chichak wrote:
>> On 2014-June-12, at 7:41 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>> The automake version is newer than what we have been using. This could
>>> be the problem. You may like to use RSB to build your autotools for
>>> RTEMS and install them to a path that you use while bootstrap/build
>>> RTEMS.
>> There was definitely a new version of automaker and autoconf that were getting in the way. I munged my .bash_profile file to make sure that the RTEMS tools took precidence over the tools from macports. That cleaned up the problems with autoconf.
> I avoid all external packing systems on MacOS and this is how I test the RSB tools.
BB-b-but cvs is missing on a clean install. sb-check bitches until you use something like macports to get one.
A
> Chris
> users mailing list
> users at rtems.org
