Issues stitching in a BSP on latest MacOS
Sat Jun 14 03:13:56 UTC 2014
On 14/06/2014 10:43 am, Mr. Andrei Chichak wrote:
> On 2014-June-13, at 4:26 PM, Chris Johns <chrisj at rtems.org> wrote:
>> On 14/06/2014 8:39 am, Mr. Andrei Chichak wrote:
>>> On 2014-June-12, at 7:41 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>>> The automake version is newer than what we have been using. This could
>>>> be the problem. You may like to use RSB to build your autotools for
>>>> RTEMS and install them to a path that you use while bootstrap/build
>>>> RTEMS.
>>> There was definitely a new version of automaker and autoconf that were getting in the way. I munged my .bash_profile file to make sure that the RTEMS tools took precidence over the tools from macports. That cleaned up the problems with autoconf.
>> I avoid all external packing systems on MacOS and this is how I test the RSB tools.
> BB-b-but cvs is missing on a clean install. sb-check bitches until you use something like macports to get one.
I built it from source. Maybe I should add it to the RSB :)
