Rtems con-current build using make -j option
Tue Jun 17 05:30:36 UTC 2014
On 17/06/2014 4:46 pm, Mohammed Khoory wrote:
> I’ve also had issues with concurrent building for the RTEMS source. I eventually gave up and simply built the source without any -j option.
>  From what I understand, the way the build system is designed makes concurrent building impossible, because some makefiles seem to depend on other makefiles finishing first. Please correct me if I'm wrong.
This is not correct. I always build with -j8 or higher and so not see
problems. The tests are nested makes and these tend to execute
sequentially (well appear to).
What type of host and the operating system ?
