End/Termination points for Classic API tasks
Martin Galvan
martin.galvan at tallertechnologies.com
Tue Jun 17 13:45:58 UTC 2014
Thanks a lot. Is it safe to assume every program will, at some point, call
_Terminate? (unless of course it's running indefinitely)
On Mon, Jun 16, 2014 at 4:08 AM, Sebastian Huber <
> On 2014-06-13 19:56, Martin Galvan wrote:
>> Hello everyone! I'm currently trying to figure out the "life cycle" of a
>> classic API task, so to speak. I've noticed single-task applications
>> (such as
>> the hello.exe example) end after a call to _User_extensions_Thread_
>> exitted (which in turn ends up in a call to _Terminate), however I'm not
>> sure
>> how tasks such as in ticker.exe end. I need to know the exact point in
>> which
>> the program ends (by that I mean where the program finishes executing and
>> RTEMS
>> starts cleaning up and calls _Terminate).
> You can terminate the program with a call to exit(). You can also use
> atexit() handlers.
> To catch all program termination paths in RTEMS you can use the fatal
> error extension.
> http://www.rtems.org/onlinedocs/doxygen/cpukit/
> html/group__ScoreUserExt.html#ga04bf84979c777ddf2507923f57b554dd
> The life cycle events for threads are covered with the create, start,
> restart, begin, exitted, delete and terminate extension.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
[image: http://www.tallertechnologies.com]
<http://www.tallertechnologies.com>
Martín Galván
Software Engineer
Taller Technologies Argentina
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: 54 351 4217888 / +54 351 4218211
[image: http://www.linkedin.com/company/taller-technologies]
<http://www.linkedin.com/company/taller-technologies>[image:
https://www.facebook.com/tallertechnologies]
<https://www.facebook.com/tallertechnologies>
URL: <http://lists.rtems.org/pipermail/users/attachments/20140617/5a96d82e/attachment.html>
