STM32F4Discovery
Steven Grunza
steven.grunza at gmail.com
Wed Jun 18 18:16:10 UTC 2014
Does anyone have an STM32F4Discovery board and the ability/desire to test a
HELLO.ELF file I built? I have a USB-to-TTL serial cable connected to the
PA9 and PA10 pins but I'm not getting any output. I have so many unknowns
in this setup that it's hard to debug.
I have a breakpoint set in Init() which I hit and a breakpoint in
output_char() which doesn't hit. Some of the console output is below:
Hardware assisted breakpoint 1 at 0x388: file test.c, line 16.
Hardware assisted breakpoint 2 at 0xe94: file
../../../../../../../../rtems.svn/c/src/lib/libbsp/arm/stm32f4/console/console-confi
g.c, line 100.
(gdb) continue
Continuing.
Temporary breakpoint 1, Init (ignored=0x20001aa0) at test.c:16
(gdb) continue
Continuing.
{After a minute or so I hit ctrl-c}
Program received signal SIGINT, Interrupt.
0x000050a2 in _Internal_error_Occurred
(the_source=the_source at entry=RTEMS_FATAL_SOURCE_EXIT,
is_internal=is_internal at entry=0x0,
the_error=0x0) at
../../../../../../rtems.svn/c/src/../../cpukit/score/src/interr.c:43
(gdb)
Any help with this would be appreciated. One bit of help would be someone
running my hello.elf file to see if it was built wrong.
The BSP mentions that https://github.com/texane/stlink was used to debug on
Linux. I'm trying to use openOCD 0.7.0 on Fedora 20.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140618/ebe4c5d3/attachment.html>
