RTEMS on Beaglebone Black
Mathew Benson
mathew.benson at gmail.com
Tue Jun 24 13:57:25 UTC 2014
You rock. Thanks.
Sent from my iPhone
> On Jun 24, 2014, at 8:53 AM, Ben Gras <beng at shrike-systems.com> wrote:
> All,
> Yes, I'm subscribed.
> Yes, I have a RTEMS BSP of the 4 beagle targets in progress - the beaglebaord, beagleboard xm, beaglebone white, and beaglebone black.
> Code is at:
> https://github.com/bengras/rtems/tree/beaglebone-wip
> Wiki page is at:
> http://wiki.rtems.org/wiki/index.php/Beagleboard
> The status is that the basics work but I want to get all (insofar as reasonable) tests passing on the bbxm and beaglebone. Also I'm working on a regression test setup using RTEMS tester. For which I'm using the RTEMS source builder so qemu-linaro is built. This way the bbxm regression test can be run without having the hardware.
> The current code runs on the bbxm but I've had a failure-report on the beaglebones (earlier commits did work on the beaglebones) so I may have broken that, I haven't checked recently.
> My roadmap is:
> - run bbxm tests running using qemu-linaro
> - debug bbxm tests in qemu-linaro
> - debug bbxm tests on hardware
> - debug beaglebone tests on hardware
>> On Tue, Jun 24, 2014 at 3:27 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> Ben.. this is yours to answer. :)
>> I didn't know if you were subscribed.
>> On 6/24/2014 8:14 AM, Mathew Benson wrote:
>> > Has anybody ported RTEMS to the Beaglebone Black?
>> > _______________________________________________
>> > users mailing list
>> > users at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/users
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20140624/046df70d/attachment-0001.html>
