problem starting a rtems task
Martínez, Pablo
pabloa.mar at gmail.com
Thu Jun 26 21:48:31 UTC 2014
On 26 June 2014 18:28, Chris Johns <chrisj at rtems.org> wrote:
> On 26/06/2014 11:54 pm, Martínez, Pablo wrote:
>> On 26 June 2014 08:37, Chris Johns <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>> On 26/06/2014 12:56 am, Martínez, Pablo wrote:
>> Hi,
>> Im having troubles trying to use the class rtemsTask from the the
>> librtems++.
>> https://github.com/atgreen/__RTEMS/blob/master/c/src/__
>> librtems%2B%2B/include/rtems%__2B%2B/rtemsTask.h
>> <https://github.com/atgreen/RTEMS/blob/master/c/src/
>> librtems%2B%2B/include/rtems%2B%2B/rtemsTask.h>
>> This class is basically a wrapper for the rtems task api.
>> I can create the task successfully (its returns 0), but when I
>> call
>> start() the entry point origin doesnt start despite returning 0
>> (this
>> method just write a memory position to check if the task is
>> working).
>> const rtems_status_code rtemsTask::start(const
>> rtems_task_argument arg)
>> if (owner)
>> argument = arg;
>> // pass the this pointer as the argument
>> set_status_code(rtems_task___start(id,
>> origin,
>> (rtems_task_argument) this));
>> else
>> set_status_code(RTEMS_NOT___OWNER_OF_RESOURCE);
>> return last_status_code();
>> Any help?
>> Are the priorities ok ? If not it might not be able to run.
>> Im using this parameters to create the task:
>> "SELF"
>> 1 (priority)
>> RTEMS_MINIMUM_STACK_SIZE
>> RTEMS_NO_PREEMPT
>> 0
>> RTEMS_NO_FLOATING_POINT
>> RTEMS_LOCAL
>> In C implementation is working fine, but the problem comes with C++.
> I would need a more complete example to know what is happening.
Chris,
Im trying to use the rtems++ library as follows:
//////////////Tempo.h
#ifndef TEMPO_H_
#define TEMPO_H_
#include <rtems++/rtemsTask.h>
#include <rtems++/rtemsTaskMode.h>
class Tempo: public rtemsTask
public:
Tempo(const char* name,
const rtems_task_priority initial_priority,
const uint32_t stack_size,
const rtems_mode preemption = RTEMS_NO_PREEMPT,
const rtems_mode timeslice = RTEMS_NO_TIMESLICE,
const rtems_mode asr = RTEMS_NO_ASR,
const rtems_interrupt_level interrupt_level = 0,
const FloatingPoint floating_point = fpoff,
const Scope scope = local);
virtual ~Tempo();
//rtems_task origin(rtems_task_argument argument);
const rtems_status_code start(const rtems_task_argument argument);
static rtems_task origen(rtems_task_argument argument);
void cuerpo(rtems_task_argument argument);
private:
// task name
rtems_name name;
char name_str[5];
// owner, true if this object owns the task
// will delete the task when it destructs
bool owner;
// the rtems id, object handle
rtems_id id;
// the argument for the task, this class uses the actual argument
// passed to RTEMS
rtems_task_argument argument;
#endif /* TEMPO_H_ */
//////////////Tempo.cpp
#include "Tempo.h"
Tempo::Tempo(const char* tname,
const rtems_mode preemption,
const rtems_mode timeslice,
const rtems_mode asr,
const rtems_interrupt_level interrupt_level,
const FloatingPoint floating_point,
const Scope scope)
: name(rtems_build_name('S', 'E', 'L', 'F')),
owner(true),
id(RTEMS_SELF),
argument(0)
strcpy(name_str, "SELF");
create(tname,
initial_priority,
stack_size,
preemption,
timeslice,
asr,
interrupt_level,
floating_point,
scope);
Tempo::~Tempo()
const rtems_status_code Tempo::start(const rtems_task_argument arg)
argument = arg;
set_status_code(rtems_task_start(id,origen,(rtems_task_argument) this));
printf (" ---Tempo::start --- \n\n");
rtems_task Tempo::origen(rtems_task_argument argument)
//just for debugging:
unsigned *regout;
regout= (unsigned*)0x80000d04;
(*regout)=0x12345678;
printf (" --- Tempo::origen --- \n\n");
Tempo *task = (Tempo*) argument;
task->cuerpo(task->argument);
void Tempo::cuerpo(rtems_task_argument )
printf (" --- Tempo::do sth --- \n\n");
" ---Tempo::start --- \n\n" gets printed, but origen() is not triggered.
Trying to solve this out, Im trying with one solution I just found (from
you!)
You use a thread template. I just found it so I haven't tested it yet.
http://comments.gmane.org/gmane.os.rtems.user/20625
cheers,
Pablo
> Chris
> thank u,
>> P
>> Chris
>> best regards,
>> Martínez, Pablo Agustín
>> _________________________________________________
>> users mailing list
>> users at rtems.org <mailto:users at rtems.org>
>> http://lists.rtems.org/__mailman/listinfo/users
>> <http://lists.rtems.org/mailman/listinfo/users>
>> users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20140626/ad39a11e/attachment.html>
