Error when compiling for Stellaris LM3S6965
Joel Sherrill
Joel.Sherrill at OARcorp.com
Wed Jun 4 19:57:50 UTC 2014
On Jun 4, 2014 1:44 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Hi Martin,
> On Wed, Jun 4, 2014 at 2:41 PM, Martin Galvan <omgalvan.86 at gmail.com> wrote:
> > Hi everyone! I'm having a problem when trying to cross-compile RTEMS for a
> > Stellaris LM3S6965 board. I checked out HEAD using
> > git clone git://git.rtems.org/rtems.git
> > and built the toolchain using the RTEMS Source Builder, after which I ran
> > the bootstrap script and did the following:
> > $../rtems/configure --target=arm-rtems4.11 --enable-rtemsbsp=lm3s6965
> > --enable-tests=samples --enable-posix
> > $ make
> > However, after a while the compilation stops with the following error:
> > /home/martin/tools/lib/gcc/arm-rtems4.11/4.8.2/../../../../arm-rtems4.11/bin/ld:
> > pppd.exe section `.rodata' will not fit in region `ROM_INT'
> > region `ROM_INT' overflowed by 45932 bytes
> > collect2: error: ld returned 1 exit status
> This error indicates that pppd is too big when compiled for it to fit
> in the memory image of the board.
This should have been addressed when Chris added the .tcfg files in various BSPs make/custom directory.
Have you rebased recently?
> > make[6]: *** [pppd.exe] Error 1
> > make[6]: Leaving directory
> > `/home/martin/tools/stellaris/arm-rtems4.11/c/lm3s6965/testsuites/samples/pppd'
> > make[5]: *** [all-local] Error 1
> > make[5]: Leaving directory
> > `/home/martin/tools/stellaris/arm-rtems4.11/c/lm3s6965/testsuites/samples'
> > make[4]: *** [all] Error 2
> > make[4]: Leaving directory
> > make[3]: *** [all-recursive] Error 1
> > make[3]: Leaving directory
> > `/home/martin/tools/stellaris/arm-rtems4.11/c/lm3s6965/testsuites'
> > make[2]: *** [all-recursive] Error 1
> > make[2]: Leaving directory
> > `/home/martin/tools/stellaris/arm-rtems4.11/c/lm3s6965'
> > make[1]: *** [all-recursive] Error 1
> > make[1]: Leaving directory `/home/martin/tools/stellaris/arm-rtems4.11/c'
> > make: *** [all-recursive] Error 1
> > Did anyone else have the same error? I don't recall tampering with anything
> > so I don't know what could be causing it.
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140604/901c360c/attachment-0001.html>
