RTEMS on Beaglebone Black
Ben Gras
beng at shrike-systems.com
Tue Jun 24 13:53:18 UTC 2014
All,
Yes, I'm subscribed.
Yes, I have a RTEMS BSP of the 4 beagle targets in progress - the
beaglebaord, beagleboard xm, beaglebone white, and beaglebone black.
Code is at:
https://github.com/bengras/rtems/tree/beaglebone-wip
Wiki page is at:
http://wiki.rtems.org/wiki/index.php/Beagleboard
The status is that the basics work but I want to get all (insofar as
reasonable) tests passing on the bbxm and beaglebone. Also I'm working on a
regression test setup using RTEMS tester. For which I'm using the RTEMS
source builder so qemu-linaro is built. This way the bbxm regression test
can be run without having the hardware.
The current code runs on the bbxm but I've had a failure-report on the
beaglebones (earlier commits did work on the beaglebones) so I may have
broken that, I haven't checked recently.
My roadmap is:
- run bbxm tests running using qemu-linaro
- debug bbxm tests in qemu-linaro
- debug bbxm tests on hardware
- debug beaglebone tests on hardware
On Tue, Jun 24, 2014 at 3:27 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> Ben.. this is yours to answer. :)
> I didn't know if you were subscribed.
> On 6/24/2014 8:14 AM, Mathew Benson wrote:
> > Has anybody ported RTEMS to the Beaglebone Black?
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20140624/cfe36b9c/attachment-0002.html>
