problem starting a rtems task
Martínez, Pablo pabloa.mar at gmail.com
Thu Jun 26 21:48:31 UTC 2014
On 26 June 2014 18:28, Chris Johns <chrisj at rtems.org> wrote:
> On 26/06/2014 11:54 pm, Martínez, Pablo wrote:
>> On 26 June 2014 08:37, Chris Johns <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>>     On 26/06/2014 12:56 am, Martínez, Pablo wrote:
>>         Hi,
>>         Im having troubles trying to use the class rtemsTask from the the
>>         librtems++.
>>         https://github.com/atgreen/__RTEMS/blob/master/c/src/__
>> librtems%2B%2B/include/rtems%__2B%2B/rtemsTask.h
>>         <https://github.com/atgreen/RTEMS/blob/master/c/src/
>> librtems%2B%2B/include/rtems%2B%2B/rtemsTask.h>
>>         This class is basically a wrapper for the rtems task api.
>>         I can create the task successfully (its returns 0), but when I
>> call
>>         start() the entry point origin doesnt start despite returning 0
>>         (this
>>         method just write a memory position to check if the task is
>>         working).
>>         const rtems_status_code rtemsTask::start(const
>>         rtems_task_argument arg)
>>         if (owner)
>>         argument = arg;
>>         // pass the this pointer as the argument
>>         set_status_code(rtems_task___start(id,
>>         origin,
>>         (rtems_task_argument) this));
>>         else
>>         set_status_code(RTEMS_NOT___OWNER_OF_RESOURCE);
>>         return last_status_code();
>>         Any help?
>>     Are the priorities ok ? If not it might not be able to run.
>> Im using this parameters to create the task:
>> "SELF"
>> 1  (priority)
>> RTEMS_MINIMUM_STACK_SIZE
>> RTEMS_NO_PREEMPT
>> 0
>> RTEMS_NO_FLOATING_POINT
>> RTEMS_LOCAL
>> In C implementation is working fine, but the problem comes with C++.
> I would need a more complete example to know what is happening.
Chris,
Im trying to use the rtems++ library as follows:
//////////////Tempo.h
#ifndef TEMPO_H_
#define TEMPO_H_
#include <rtems++/rtemsTask.h>
#include <rtems++/rtemsTaskMode.h>
class Tempo: public rtemsTask
public:
    Tempo(const char* name,
            const rtems_task_priority initial_priority,
            const uint32_t stack_size,
            const rtems_mode preemption = RTEMS_NO_PREEMPT,
            const rtems_mode timeslice = RTEMS_NO_TIMESLICE,
            const rtems_mode asr = RTEMS_NO_ASR,
            const rtems_interrupt_level interrupt_level = 0,
            const FloatingPoint floating_point = fpoff,
            const Scope scope = local);
    virtual ~Tempo();
    //rtems_task origin(rtems_task_argument argument);
    const rtems_status_code start(const rtems_task_argument argument);
    static rtems_task origen(rtems_task_argument argument);
    void cuerpo(rtems_task_argument argument);
private:
      // task name
      rtems_name name;
      char name_str[5];
      // owner, true if this object owns the task
      // will delete the task when it destructs
      bool owner;
      // the rtems id, object handle
      rtems_id id;
      // the argument for the task, this class uses the actual argument
      // passed to RTEMS
      rtems_task_argument argument;
#endif /* TEMPO_H_ */
//////////////Tempo.cpp
#include "Tempo.h"
Tempo::Tempo(const char* tname,
                     const rtems_mode preemption,
                     const rtems_mode timeslice,
                     const rtems_mode asr,
                     const rtems_interrupt_level interrupt_level,
                     const FloatingPoint floating_point,
                     const Scope scope)
  : name(rtems_build_name('S', 'E', 'L', 'F')),
    owner(true),
    id(RTEMS_SELF),
    argument(0)
  strcpy(name_str, "SELF");
  create(tname,
         initial_priority,
         stack_size,
         preemption,
         timeslice,
         asr,
         interrupt_level,
         floating_point,
         scope);
Tempo::~Tempo()
const rtems_status_code Tempo::start(const rtems_task_argument arg)
    argument = arg;
    set_status_code(rtems_task_start(id,origen,(rtems_task_argument) this));
    printf ("   ---Tempo::start  --- \n\n");
rtems_task Tempo::origen(rtems_task_argument argument)
    //just for debugging:
    unsigned *regout;
    regout= (unsigned*)0x80000d04;
    (*regout)=0x12345678;
    printf ("   --- Tempo::origen  --- \n\n");
  Tempo *task = (Tempo*) argument;
  task->cuerpo(task->argument);
void Tempo::cuerpo(rtems_task_argument )
    printf ("   --- Tempo::do sth  --- \n\n");
"  ---Tempo::start  --- \n\n" gets printed, but origen() is not triggered.
Trying to solve this out, Im trying with one solution I just found (from
you!)
You use a thread template. I just found it so I haven't tested it yet.
http://comments.gmane.org/gmane.os.rtems.user/20625
cheers,
Pablo
> Chris
>  thank u,
>> P
>>     Chris
>>         best regards,
>>         Martínez, Pablo Agustín
>>         _________________________________________________
>>         users mailing list
>>         users at rtems.org <mailto:users at rtems.org>
>>         http://lists.rtems.org/__mailman/listinfo/users
>>         <http://lists.rtems.org/mailman/listinfo/users>
>>     users mailing list
URL: <http://lists.rtems.org/pipermail/users/attachments/20140626/ad39a11e/attachment-0002.html>
