Mkprom2 & Rtems
Martínez, Pablo pabloa.mar at gmail.com
Tue Mar 11 19:33:22 UTC 2014
Hello all,
following many posts and documentations on this group and Gaisler support,
I have proved many configurations about loading a Rtems application on PROM.
CODE:
// The following code write many memory address with the same value
#define CONFIGURE_INIT
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_TASKS             4
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_EXTRA_TASK_STACKS         (3 * RTEMS_MINIMUM_STACK_SIZE)
#include "system.h"
rtems_task Init(
  rtems_task_argument argument
    unsigned *mem1;
    int i;
    mem1 = 0X400a0000;
    for (i=0; i<200; i++)
    (*mem1) = 0x55555555;
    mem1++;
exit(0);
I Could implement and run in flash (PROM) the code without Rtems (using:
sparc-elf-gcc and mkprom2)
Now, I need implement the code with Rtems, for that reason I have compiled
the below code with:
 sparc-rtems-gcc and/or sparc-rtems4.10-gcc In both case I can create the
"executable" using Rtems Sparc and Rtems Toolchain on Eclipse.those
implementations have been proved on target (Xilinx Kintex KC-705) and they
run perfect.
Now, I need to have this code in PROM. for that reason I did the following
steps:
1) Created the ".exe" file with Rtems Toolchain on Eclipse
2) Created the prom.out using mkprom (with many configurations)
mkprom2 -msoft-float -ramsize 1024000 -nosram -sdram 1024 -romsize 128000
-romwidth 16 -freq 50 -baud 83400 -rmw -ccprefix sparc-rtems mem_prom_rtems
I can generate the "prom.out" but is not working on the target.... (flash
erase all; flash load prom.out, flash lock all)
Could somebody give me an explanation about what I'm doing wrong?, or give
me an advice to create the prom.out successfully?
Regards,
Martínez, Pablo Agustín
URL: <http://lists.rtems.org/pipermail/users/attachments/20140311/b0b53e78/attachment.html>
