Mkprom2 & Rtems
    Martínez, Pablo
    pabloa.mar at gmail.com
    Tue Mar 11 20:56:10 UTC 2014
I have been working on the following checks... What do you think?
1) Memory configuration on Target:
  mig0      Aeroflex Gaisler  Xilinx MIG DDR3 Controller
            AHB: 40000000 - 80000000      /*RAM SPACE [I'M NOT USING SRAM]*/
            APB: 80000400 - 80000500
            SDRAM: 1024 Mbyte
2) PROGRAM RUNING IN RAM:
grmon2> load /home/publico/facundo/mem_prom_rtems
  40000000 .text                    130.8kB / 130.8kB   [===============>]
100%
  40020B50 .data                      4.4kB /   4.4kB   [===============>]
100%
  40021D00 .jcr                         4B              [===============>]
100%
  Total size: 135.25kB (93.91kbit/s)
  Entry point 0x40000000
  Image /home/publico/facundo/mem_prom_rtems loaded
grmon2> run
  Program exited normally.
grmon2> mem -ascii 0x400a0000 20
  0x400a0000  55555555  55555555  55555555  55555555    UUUUUUUUUUUUUUUU
  0x400a0010  55555555                                  UUUU
3) Build the prom.out (for PROM):
# mkprom2 -msoft-float -ramsize 1024000 -nosram -sdram 1024 -romsize 128000
-romwidth 16 -freq 50 -baud 83400 -rmw -ccprefix sparc-rtems mem_prom_rtems
NOTE: "mem_prom_rtems is the code that I have loaded in Ram"
4) PROGRAM LOAD IN FLASH (PROM)
grmon2> flash unlock all
  Unlock complete
grmon2> flash erase all
  Erase in progress
  Block @ 0x07ff8000 : code = 0x80  OK
  Erase complete
grmon2> flash load /home/publico/facundo/prom.out
  00000000 .text                     84.8kB /  84.8kB   [===============>]
100%
  Total size: 84.81kB (76.08kbit/s)
  Entry point 0x0
  Image /home/publico/facundo/prom.out loaded
grmon2>
5) (after Reset)
  0x400a0000  40acbebf  78171d5a  e7c78a5b  db3ddfe3    @...x..Z...[.=..
  0x400a0010  e67aeb3c                                  .z.<
Is for that reason that I know why the program is not running. This code
(without Rtems)has been working perfectly using sparc-elf-gcc and mkprom2.
On 11 March 2014 16:46, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 3/11/2014 2:33 PM, Martínez, Pablo wrote:
>  Hello all,
>  following many posts and documentations on this group and Gaisler
> support, I have proved many configurations about loading a Rtems
> application on PROM.
>  CODE:
>  // The following code write many memory address with the same value
> #include <stdio.h>
> #include <stdlib.h>
> #define CONFIGURE_INIT
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_MAXIMUM_TASKS             4
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_EXTRA_TASK_STACKS         (3 * RTEMS_MINIMUM_STACK_SIZE)
> #include "system.h"
> rtems_task Init(
>   rtems_task_argument argument
>     unsigned *mem1;
>     int i;
>     mem1 = 0X400a0000;
>     for (i=0; i<200; i++)
>     (*mem1) = 0x55555555;
>     mem1++;
> exit(0);
>  I Could implement and run in flash (PROM) the code without Rtems (using:
> sparc-elf-gcc and mkprom2)
>  Now, I need implement the code with Rtems, for that reason I have
> compiled the below code with:
>  sparc-rtems-gcc and/or sparc-rtems4.10-gcc In both case I can create the
> "executable" using Rtems Sparc and Rtems Toolchain on Eclipse.those
> implementations have been proved on target (Xilinx Kintex KC-705) and they
> run perfect.
>  Now, I need to have this code in PROM. for that reason I did the
> following steps:
>  1) Created the ".exe" file with Rtems Toolchain on Eclipse
>  2) Created the prom.out using mkprom (with many configurations)
>  I can generate the "prom.out" but is not working on the target....
> (flash erase all; flash load prom.out, flash lock all)
>  Could somebody give me an explanation about what I'm doing wrong?, or
> give me an advice to create the prom.out successfully?
>   Does it get to Init()?
> What does it do when it is not working? There isn't much going on in your
> program
> so it would just run and exit. If the loop doesn't corrupt something
> important.
>   Regards,
> Martínez, Pablo Agustín
> Joel Sherrill, Ph.D.             Director of Research & Developmentjoel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20140311/7358f0dd/attachment.html>
