potential GSOC project: Improve the Raspberry Pi BSP
Alan Cudmore
alan.cudmore at gmail.com
Fri Mar 14 02:33:26 UTC 2014
Andre,
I think your project proposal looks good, but I wonder if including USB
support is too much. There are low level "bare metal" USB examples out
there for the Raspberry Pi, and that may serve as a starting point, but I
think a real USB implementation will use the BSD library that has been
ported to RTEMS. It may be possible, since there is a FreeBSD port to the
Raspberry Pi. Maybe others can help here.
If you think that GPIO, SPI, and I2C are not enough, then you could always
look at the framebuffer or SD card access.
Finally, it may be necessary to have an Raspberry Pi and a few peripherals.
For example, I have an inexpensive I2C compass module that I use with
linux, and I have a breadboard wired up with LEDs to test GPIO.
Thanks,
Alan
On Thu, Mar 13, 2014 at 8:32 PM, Alan Cudmore <alan.cudmore at gmail.com>wrote:
> I'm glad there is interest in this project. Andre, I will read your
> proposal and provide feedback.
> Joel, I was on the melange site and the system recognizes my account. Do I
> need to do anything to be a mentor for RTEMS?
> Alan
> On Thu, Mar 13, 2014 at 7:31 PM, Andre Marques <
> andre.lousa.marques at gmail.com> wrote:
>> It is now on melange too.
>> --André Marques.
>> On 03/13/14 23:21, Hesham Moustafa wrote:
>> Hi Andre,
>> I quote from RTEMS SoC page :
>> "GSOC STUDENTS! PLEASE FILL IN THE APPLICATION AT
>> http://www.google-melange.com! YOU CAN EDIT UNTIL THE DEADLINE! BUT YOU
>> WILL NOT GET A SLOT IF YOU DO NOT APPLY THROUGH Google!!!"
>> Regards,
>> Hesham
>> On Fri, Mar 14, 2014 at 1:16 AM, Andre Marques <
>>> Hello,
>>> I just posted the first proposal draft for "Raspberry Pi BSP Peripherals
>>> " in the RTEMS Wiki
>>> http://wiki.rtems.org/wiki/index.php/RTEMSSummerOfCode
>>> Any feedback is more than welcome. Should I post it already in melange
>>> too?
>>> --André Marques.
>>> On 03/13/14 15:26, Joel Sherrill wrote:
>>> On 3/13/2014 9:46 AM, Andre Marques wrote:
>>> Hello,
>>> I would be very interested in working in this project because I'm
>>> currently trying to work with Raspberry Pi and RTEMS for my undergraduate
>>> thesis, so this could be a great followup to that for the summer.
>>> I will need to do some reseach on it before making a proposal (the time
>>> is also gettting shorter), but will post a proposal draft very soon.
>>> This would be a great area to work. As Alan says, the list is likely too
>>> much for
>>> one student, so it seems likely that the work could be divided for two
>>> students
>>> working on different parts.
>>> For the Pi Master list, I would like to add the Geert board. That looks
>>> like something
>>> of interest to RTEMS folks.
>>> --joel
>>> --André Marques.
>>> On 03/13/14 11:23, Alan Cudmore wrote:
>>> ( I posted this to the rtems-devel list by mistake, my apologies for the
>>> duplicate message )
>>> f there are still potential GSOC students out there looking for a
>>> project, I would like to offer a potential project to work on: Improving
>>> the Raspberry Pi BSP. I would be happy to mentor a student for this
>>> project. Below is my description for the task.
>>> Thanks,
>>> Alan
>>> One of the RTEMS Open Projects is to contribute a BSP or Board Support
>>> Package for readily available boards. The Raspberry Pi is probably the most
>>> available board at $25 and $35 USD, and there have been over two million of
>>> these boards sold. The RTEMS head (4.11) currently has a basic BSP for the
>>> Raspberry Pi, supporting the CPU, a single UART, and timer. It is enough to
>>> run some basic RTEMS programs, but expanding the BSP to support peripherals
>>> will make it much more useful.
>>> For this project, the GSOC student could improve the peripheral support
>>> for the Raspberry Pi BSP.
>>> The peripherals we need to support (in order of increasing difficulty)
>>> include:
>>> 1. GPIO (This has been done by one user, but is not integrated)
>>> 2. I2C Bus
>>> 3. SPI Bus
>>> 4. Secure Digital card read and write support (using the SPI bus)
>>> 5. Graphics / RTEMS Framebuffer Support (I have a graphics demo working
>>> in an RTEMS task)
>>> 6. USB Device support
>>> 7. HDMI/Graphics console (Requires framebuffer support and USB or GPIO
>>> connected keyboard device)
>>> 8. Ethernet network support (Requires USB support)
>>> The entire list is probably too much for a single student to accomplish,
>>> so we can adjust the list of work according to what is possible.
>>> It may also be a good idea to add support for both models of the
>>> Raspberry Pi (256MB and 512MB) and be able to configure the memory map in
>>> the BSP to match the boot time split between the CPU and GPU memory.
>>> Finally, in order to do some of this coding, it may be necessary to
>>> come up with a more efficient way to load and debug code on the Raspberry
>>> Pi. Options include using U-boot or connecting a JTAG debug device to load
>>> code.
>>> rtems-users mailing listrtems-users at rtems.orghttp://www.rtems.org/mailman/listinfo/rtems-users
>>> Joel Sherrill, Ph.D. Director of Research & Developmentjoel.sherrill at OARcorp.com On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20140313/c362e644/attachment-0001.html>
