potential GSOC project: Improve the Raspberry Pi BSP
Wed Mar 19 20:35:13 UTC 2014
On 3/19/2014 3:33 PM, Pierre Ficheux wrote:
> USB should be interesting too on RPi because of Ethernet support ;)
Yep. USB and Ethernet are tied together in the new tcp/ip stack.
> Regarding SD card you should take a look at U-Boot for RPi which includes MMC support in drivers/mmc. U-Boot includes USB support for RPi too in drivers/usb.
> https://github.com/gonzoua/u-boot-pi
U-Boot is GPL V3 and is off limits to lift code from.
Minix or FreeBSD are better options.
> regards
> ----- Mail original -----
>> De: "Andre Marques" <andre.lousa.marques at gmail.com>
>> À: "Alan Cudmore" <alan.cudmore at gmail.com>
>> Cc: rtems-users at rtems.org
>> Envoyé: Mercredi 19 Mars 2014 20:59:56
>> Objet: Re: potential GSOC project: Improve the Raspberry Pi BSP
>> Hello Alan,
>> I have decided to go with the framebuffer instead of the USB support.
>> Will update the proposal with this.
>> Before GSOC I am considering to look at the SD card access through
>> the onboard card reader. What do you think?
>> --André Marques.
>> On 03/19/14 00:56, Alan Cudmore wrote:
>> Hi André ,
>> I agree about the USB stack. I am not even sure about how to
>> integrate a driver that depends on the FreeBSD USB stack.
>> The GPIO driver from Pierre is the one I was referring to. I don't
>> think anyone ever made a decision on how to integrate the GPIO
>> driver. If we have macros in the BSP header files then the GPIO can
>> be programmed with the simple macros or the driver that Pierre
>> wrote. If the project decides to use the GPIO device model for other
>> BSPs, then the generic driver code can be moved to a shared
>> directory at a later date.
>> Thanks for the update,
>> Alan
>> On Tue, Mar 18, 2014 at 11:04 AM, Andre Marques <
>> andre.lousa.marques at gmail.com > wrote:
>> Hello,
>> about the USB driver port from FreeBSD I am finding it difficult to
>> gauge how much work it would involve, so I will follow your
>> suggestion and look at something else.
>> As for GPIO I belive the work that has been done is this:
>> https://github.com/pficheux/raspberry_pi/tree/master/RTEMS/gpio_driver
>> Am I right?
>> I also found a discussion on the best way of implementing the driver
>> http://www.rtems.org/pipermail/rtems-users/2013-October/012059.html
>> but i am not sure if that came to a decision.
>> Meanwhile I will update the proposal with some basic info on the
>> drivers.
>> --André Marques.
>> On 03/14/14 13:16, Andre Marques wrote:
>> Hello,
>> On 03/14/14 02:33, Alan Cudmore wrote:
>> Andre,
>> I think your project proposal looks good, but I wonder if including
>> USB support is too much. There are low level "bare metal" USB
>> examples out there for the Raspberry Pi, and that may serve as a
>> starting point, but I think a real USB implementation will use the
>> BSD library that has been ported to RTEMS. It may be possible, since
>> there is a FreeBSD port to the Raspberry Pi. Maybe others can help
>> here.
>> I will take a look into this.
>> If you think that GPIO, SPI, and I2C are not enough, then you could
>> always look at the framebuffer or SD card access.
>> Yes, right now I am trying to clarify everything the best I can so I
>> don't end up with a lot more (or less) work than I can handle.
>> Finally, it may be necessary to have an Raspberry Pi and a few
>> peripherals. For example, I have an inexpensive I2C compass module
>> that I use with linux, and I have a breadboard wired up with LEDs to
>> test GPIO.
>> Right now I have access to a Raspberry Pi at the university, not sure
>> about the peripherals though. Anyway, if this projects really goes
>> forward I will get myself a raspberry and peripherals (I have
>> already some other components, like a breadboard, leds, wire, etc).
>> Thanks,
>> Alan
>> On Thu, Mar 13, 2014 at 8:32 PM, Alan Cudmore <
>> alan.cudmore at gmail.com > wrote:
>> I'm glad there is interest in this project. Andre, I will read your
>> proposal and provide feedback.
>> Joel, I was on the melange site and the system recognizes my account.
>> Do I need to do anything to be a mentor for RTEMS?
>> Alan
>> On Thu, Mar 13, 2014 at 7:31 PM, Andre Marques <
>> It is now on melange too.
>> --André Marques.
>> On 03/13/14 23:21, Hesham Moustafa wrote:
>> Hi Andre,
>> I quote from RTEMS SoC page :
>> "GSOC STUDENTS! PLEASE FILL IN THE APPLICATION AT
>> http://www.google-melange.com ! YOU CAN EDIT UNTIL THE DEADLINE! BUT
>> YOU WILL NOT GET A SLOT IF YOU DO NOT APPLY THROUGH Google!!!"
>> Regards,
>> Hesham
>> On Fri, Mar 14, 2014 at 1:16 AM, Andre Marques <
>> Hello,
>> I just posted the first proposal draft for "Raspberry Pi BSP
>> Peripherals " in the RTEMS Wiki
>> http://wiki.rtems.org/wiki/index.php/RTEMSSummerOfCode
>> Any feedback is more than welcome. Should I post it already in
>> melange too?
>> --André Marques.
>> On 03/13/14 15:26, Joel Sherrill wrote:
>> On 3/13/2014 9:46 AM, Andre Marques wrote:
>> Hello,
>> I would be very interested in working in this project because I'm
>> currently trying to work with Raspberry Pi and RTEMS for my
>> undergraduate thesis, so this could be a great followup to that for
>> the summer.
>> I will need to do some reseach on it before making a proposal (the
>> time is also gettting shorter), but will post a proposal draft very
>> soon.
>> This would be a great area to work. As Alan says, the list is likely
>> too much for
>> one student, so it seems likely that the work could be divided for
>> two students
>> working on different parts.
>> For the Pi Master list, I would like to add the Geert board. That
>> looks like something
>> of interest to RTEMS folks.
>> --joel
>> --André Marques.
>> On 03/13/14 11:23, Alan Cudmore wrote:
>> ( I posted this to the rtems-devel list by mistake, my apologies for
>> the duplicate message )
>> f there are still potential GSOC students out there looking for a
>> project, I would like to offer a potential project to work on:
>> Improving the Raspberry Pi BSP. I would be happy to mentor a student
>> for this project. Below is my description for the task.
>> Thanks,
>> Alan
>> One of the RTEMS Open Projects is to contribute a BSP or Board
>> Support Package for readily available boards. The Raspberry Pi is
>> probably the most available board at $25 and $35 USD, and there have
>> been over two million of these boards sold. The RTEMS head (4.11)
>> currently has a basic BSP for the Raspberry Pi, supporting the CPU,
>> a single UART, and timer. It is enough to run some basic RTEMS
>> programs, but expanding the BSP to support peripherals will make it
>> much more useful.
>> For this project, the GSOC student could improve the peripheral
>> support for the Raspberry Pi BSP.
>> The peripherals we need to support (in order of increasing
>> difficulty) include:
>> 1. GPIO (This has been done by one user, but is not integrated)
>> 2. I2C Bus
>> 3. SPI Bus
>> 4. Secure Digital card read and write support (using the SPI bus)
>> 5. Graphics / RTEMS Framebuffer Support (I have a graphics demo
>> working in an RTEMS task)
>> 6. USB Device support
>> 7. HDMI/Graphics console (Requires framebuffer support and USB or
>> GPIO connected keyboard device)
>> 8. Ethernet network support (Requires USB support)
>> The entire list is probably too much for a single student to
>> accomplish, so we can adjust the list of work according to what is
>> possible.
>> It may also be a good idea to add support for both models of the
>> Raspberry Pi (256MB and 512MB) and be able to configure the memory
>> map in the BSP to match the boot time split between the CPU and GPU
>> memory.
>> Finally, in order to do some of this coding, it may be necessary to
>> come up with a more efficient way to load and debug code on the
>> Raspberry Pi. Options include using U-boot or connecting a JTAG
>> debug device to load code.
>> rtems-users mailing list rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available (256) 722-9985
