Error in running test: "error: no executbles supplied"
Kumar Amit Mehta
gmate.amit at gmail.com
Sun May 11 20:14:04 UTC 2014
Hi,
I'm trying to run the rtems testcases for the first time and facing some
issues with the setup (most probably). Invoking 'rtems-test' gives me
the error; "error: no executbles supplied". I wonder, what is it that
I've missed. Please see the directory structure, toolset etc information
below for more information.
bash-4.1$ ./rtems-test --log=log_sis_run --rtems-bsp=sis-run --rtems-tools=$HOME/development/rtems/4.11
$HOME/development/rtems/kernel/sis
RTEMS Testing - Tester, v0.2.0
error: no executbles supplied <---- :(
bash-4.1$ ./rtems-test --list-bsps
BSP List:
beagleboardxm
mcf5235
psim-run
psim
realview_pbx_a9_qemu
sis-run
sis
xilinx_zynq_a9_qemu
xilinx_zynq_a9_qemu_smp
xilinx_zynq_zc706
bash-4.1$ echo $PATH
/home/rtems/development/rtems/4.11/bin:/usr/lib/qt-3.3/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/home/rtems/bin
bash-4.1$ ls -l $HOME/development/rtems/4.11
total 24
drwxr-xr-x. 2 rtems rtems 4096 May 10 12:44 bin
drwxr-xr-x. 3 rtems rtems 4096 May 10 12:44 include
drwxr-xr-x. 4 rtems rtems 4096 May 10 12:44 lib
drwxr-xr-x. 3 rtems rtems 4096 May 10 12:39 libexec
drwxr-xr-x. 14 rtems rtems 4096 May 10 12:44 share
drwxr-xr-x. 5 rtems rtems 4096 May 10 12:40 sparc-rtems4.11
bash-4.1$ ls -l $HOME/development/rtems/kernel/sis
total 84
-rw-rw-r--. 1 rtems rtems 8388 May 11 14:35 config.log
-rwxrwxr-x. 1 rtems rtems 26783 May 11 14:35 config.status
-rw-rw-r--. 1 rtems rtems 31986 May 11 14:35 Makefile
drwxrwxr-x. 3 rtems rtems 4096 May 11 14:35 sparc-rtems4.11
drwxrwxr-x. 3 rtems rtems 4096 May 11 14:35 testsuites
drwxrwxr-x. 4 rtems rtems 4096 May 11 14:35 tools
bash-4.1$ which sparc-rtems4.11-gcc
/home/rtems/development/rtems/4.11/bin/sparc-rtems4.11-gcc
The SPARC tool chain was created by doing the following:
1: Create a directory for tools(necessary tools for cross compilation
etc.)
bash-4.1$ mkdir -p development/rtems/src
2: Clone the rtems source builder using git
bash-4.1$ git clone git://git.rtems.org/rtems-source-builder.git
bash-4.1$ cd /home/rtems/development/rtems/
src/rtems-source-builder
3: Build the tools
bash-4.1$ cd rtems
bash-4.1$ ../source-builder/sb-set-builder --log=l-sparc.txt --prefix=/home/rtems/development/rtems/4.11 4.11/rtems-sparc
RTEMS Source Builder - Set Builder, v0.2.0
Build Set: 4.11/rtems-sparc
4: Export the path
bash-4.1$ export PATH=$HOME/development/rtems/4.11/bin/:$PATH
I'm following the instructions mentioned in the rtems-tools/doc/rtems-tester.txt[1].
[1] git://git.rtems.org/rtems-tools.git
Thanks,
Kumar
