[ESA summer of code, 2014] RTEMS testing
Jennifer Averett Jennifer.Averett at OARcorp.com
Tue May 13 18:11:16 UTC 2014
> -----Original Message-----
> From: rtems-users-bounces at rtems.org [mailto:rtems-users-
> bounces at rtems.org] On Behalf Of Kumar Amit Mehta
> Sent: Tuesday, May 13, 2014 12:55 PM
> To: Joel Sherrill
> Cc: rtems users; amar at rtems.org
> Subject: Re: [ESA summer of code, 2014] RTEMS testing
> On Tue, May 13, 2014 at 10:50:07AM -0500, Joel Sherrill wrote:
> > There are two sets of scripts to run those tests. One is rtems-testing/sim-
> scripts in bash and the other next generation is rtems-test which is in Python.
> The newer code in Python drives gdb and can support automated testing on
> real hardware. The bash scripts just drove simulators but supported more
> bsps than the newer Python code. We are in transition and this is part of the
> project.
> I looked in the rtems/testsuites directory looking for the bash script that you
> mentioned here, but couldn't find it. Can you please point me to the script,
> so that, I can try to find the BSP support that are not yet implemented in the
> rtems-tools(git://git.rtems.org/rtems-tools.git).
> The bsps supported by rtems-tools seem to be mentioned under:
> ~/rtems-tools/tester/rtems/testing/bsps
> > Using rtems-testing/sim-scripts, it is as simple as sis *.exe. The rtems-test
> scripts are also easy but I can't do the command from my phone.
> Same as above.
If I understand correctly you are looking in the wrong tree.
Look in git://git.rtems.org/rtems-testing.git.  The sis script is in the
bin directory.
> Thanks,
> Kumar
> rtems-users mailing list
> rtems-users at rtems.org
