RTEMS shell and telnetd
Peter Dufault
dufault at hda.com
Wed May 28 15:04:50 UTC 2014
I'm figuring out how we're supposed to hook telnetd and RTEMS shell together in the git head and I don't understand the intent. I used to do it like this:
static void sh_wrap(char *unused_dev, void *arg)
rtems_shell_env_t my_env = rtems_global_shell_env;
my_env.forever = false;
(void)rtems_shell_main_loop( &my_env );
rtems_telnetd_config_table rtems_telnetd_config = {
sh_wrap, /* Command */
NULL, /* Argument */
0, /* Priority */
20 * RTEMS_MINIMUM_STACK_SIZE, /* task stack size */
0, /* Login check */
0 /* Keep stdio of the caller */
and later call:
rtems_telnetd_initialize();
"rtems_global_shell_env" is no longer global. "rtems_shell_init_env()" which would initialize a rtems_shell_env_t is not global. "rtems_shell_get_current_env()" won't work outside of a shell context. Passing 0 to rtems_shell_main_loop(0) will get the default settings for the shell env, so forever will be set true and I won't be able to exit the session.
Am I missing something or is the intention I set up a "my_env" myself? rtems_shell_env_t is still global.
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
