[ESA summer of code, 2014] RTEMS testing
    Joel Sherrill
    Joel.Sherrill at OARcorp.com
    Tue May 13 18:20:08 UTC 2014
On May 13, 2014 1:11 PM, Jennifer Averett <Jennifer.Averett at OARcorp.com> wrote:
> > -----Original Message-----
> > From: rtems-users-bounces at rtems.org [mailto:rtems-users-
> > bounces at rtems.org] On Behalf Of Kumar Amit Mehta
> > Sent: Tuesday, May 13, 2014 12:55 PM
> > To: Joel Sherrill
> > Cc: rtems users; amar at rtems.org
> > Subject: Re: [ESA summer of code, 2014] RTEMS testing
> > On Tue, May 13, 2014 at 10:50:07AM -0500, Joel Sherrill wrote:
> > > There are two sets of scripts to run those tests. One is rtems-testing/sim-
> > scripts in bash and the other next generation is rtems-test which is in Python.
> > The newer code in Python drives gdb and can support automated testing on
> > real hardware. The bash scripts just drove simulators but supported more
> > bsps than the newer Python code. We are in transition and this is part of the
> > project.
> > I looked in the rtems/testsuites directory looking for the bash script that you
> > mentioned here, but couldn't find it. Can you please point me to the script,
> > so that, I can try to find the BSP support that are not yet implemented in the
> > rtems-tools(git://git.rtems.org/rtems-tools.git).
> > The bsps supported by rtems-tools seem to be mentioned under:
> > ~/rtems-tools/tester/rtems/testing/bsps
> > > Using rtems-testing/sim-scripts, it is as simple as sis *.exe. The rtems-test
> > scripts are also easy but I can't do the command from my phone.
> > Same as above.
> If I understand correctly you are looking in the wrong tree.
> Look in git://git.rtems.org/rtems-testing.git.  The sis script is in the
> bin directory.
After you type make. :)
> > Thanks,
> > Kumar
> > rtems-users mailing list
> > rtems-users at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140513/3856f3b6/attachment-0001.html>
