[ESA summer of code, 2014] RTEMS testing
Kumar Amit Mehta gmate.amit at gmail.com
Tue May 13 21:22:44 UTC 2014
On Tue, May 13, 2014 at 01:18:47PM -0500, Joel Sherrill wrote:
> The names are unfortunately close so read carefully.
So there are in total four different repositories.
> rtems/testsuites is C/C++ for test cases and executables. These are what is run on target hardware and simulators.
git://git.rtems.org/rtems.git
> rtems-testing/sim-scripts is bash scripts to automate running all the above tests.
git://git.rtems.org/rtems-testing.git
> rtems-test is a newer Python based scripts to automate running the same tests
git://git.rtems.org/rtems-tools.git
> rtems-tools is the place we put patches for third party programs like GCC, gdb, and qemu unto they are merged into the upstream repository and released.
git://git.rtems.org/rtems-source-builder.git
Thank you for clarification.
Thanks,
Kumar
