rtems-tools daily test results
Joel Sherrill
Joel.Sherrill at OARcorp.com
Sat May 17 14:27:37 UTC 2014
That's the goal of all the work. Amar is working on the buildbot instance. We are focusing on the per BSP testing automation, coverage, simulators, tools, and reproducibility of what we have now. Amar worked with an SOCIS student on a new test coding framework.
When it all comes together we will be doing testing on every commit.
The SOCIS projects are focused on improving what we have and evolving it toward the new way.
Post results for what you have and we can comment.
On May 16, 2014 7:58 PM, Kumar Amit Mehta <gmate.amit at gmail.com> wrote:
Are rtems-tools(the 3rd generation python test framework) based tests
invoked daily on some machine for a combination of BSP, Simulator and
target ? If yes, then where can I find a report for these runs ?
Thanks,
Kumar
rtems-users mailing list
rtems-users at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20140517/938941bd/attachment-0001.html>
