rtems-tools daily test results
Mon May 19 00:26:48 UTC 2014
On 18/05/2014 9:52 pm, Kumar Amit Mehta wrote:
> On Sat, May 17, 2014 at 09:27:37AM -0500, Joel Sherrill wrote:
>> Post results for what you have and we can comment.
> <snip>
> RTEMS Testing - Tester, v0.2.0
>   Command Line: ./rtems-test --log=log_sis_run --rtems-bsp=sis-run
> --rtems-tools=/home/rtems/development/rtems/4.11
> /home/rtems/development/rtems/kernel/sis
>   Python: 2.6.6 (r266:84292, Sep 11 2012, 08:28:27) [GCC 4.4.6 20120305
> (Red Hat 4.4.6-4)]
> Passed:   492
> Failed:     1
> Timeouts:   1
> Invalid:    0
> Total:    494
> Failures:
>   sp2038.exe
> Timeouts:
>   pppd.exe
> Testing time: 0:24:37.792244
> <snip>
> <Failures>
> [286/494] p:284 f:0   t:1   i:0   | sparc/sis: sp2038.exe
>> run: /home/rtems/development/rtems/4.11/bin/sparc-rtems4.11-run -a
>> -nouartrx
>> /home/rtems/development/rtems/kernel/sis/sparc-rtems4.11/c/sis/testsuites/sptests/sp2038/sp2038.exe
> ] unknown option -nouartrx
> ] *** BEGIN OF TEST SP 2038 ***
> ../../../../../../../rtems.git/c/src/../../testsuites/sptests/sp2038/init.c:
> 269 memcmp(&now, problem, sizeof(now)) == 0
> Result: failed     Time: 0:00:01.045045
> <Failures>
I thought this one was fixed. I am not seeing a failure with it.
> <timeout>
> [264/494] p:263 f:0   t:0   i:0   | sparc/sis: pppd.exe
>> -nouartrx
>> /home/rtems/development/rtems/kernel/sis/sparc-rtems4.11/c/sis/testsuites/samples/pppd/pppd.exe
> ] *** BEGIN OF TEST PPPD ***
> ] pppd: In secrets file: unrecognized option '/dev/ttyS1'
> ] Serial connection established.
> ] ioctl(TIOCGETD): Bad file number
> ] ioctl(TIOCSETD): Bad file number
> ] ioctl(PPPIOCGUNIT): Bad file number
> ] Couldn't set device to non-blocking mode: Bad file number
> ] *** TIMEOUT TIMEOUT
> <timeout>
This test is interactive and needs to be patched with a key a hit to
start like some of the other interactive tests.
> In an organization, where I have worked before, somebody setup
> jenkins[1] for building, invoking test and notification through email.
Great to hear continuous integration being used.
> Maybe same, can be implemented for rtems tests too.
> [1] http://jenkins-ci.org/
We will use buildbot. It is something Amar knows well as he is involved
in the buildbot project.
