RTEMS BSD select demo testing using loopback interface.
Thomas Kim
thomas73.kim at gmail.com
Mon May 19 08:51:53 UTC 2014
Dear Sir,
Please disregard this email thread.
I found test code in testsuites/samples/lookback.
It is working...
Best Regards.
2014-05-19 17:45 GMT+09:00 Thomas Kim <thomas73.kim at gmail.com>:
> Dear Sir,
> I think that select demo is not worked. I switched to netdemo.
> Because my testing case is loopback only, I changed below points.
> //#define DATA_SINK_HOST ((128 << 24) | (233 << 16) | (14 << 8) | 60)
> #define DATA_SINK_HOST ((127 << 24) | (0 << 16) | (0 << 8) | 1)
> #define MY_HOST ((127 << 24) | (0 << 16) | (0 << 8) | 1)
> both DATA_SINK_HOST and MY_HOST is local IP address, "127.0.0.1".
> Also, I changed INADDR_ANY to MY_HOST in socket structure.
> Even though I changed this, netdemo is not working.
> Please check this.
> Best Regards
> 2014-05-19 17:15 GMT+09:00 Thomas Kim <thomas73.kim at gmail.com>:
>> Dear Sir,
>> I am beginner using BSD socket API.
>> I am testing select demo in network-demos-4.10-2 examples using loopback
>> interface only.
>> I inserted rtems_bsdnet_show_inet_routes() function before calling
>> doSelect () as like below;
>> rtems_task
>> Init (rtems_task_argument ignored)
>> int doSocket(void);
>> rtems_bsdnet_initialize_network ();
>> rtems_bsdnet_show_inet_routes();
>> doSocket ();
>> exit (0);
>> As I check print log, getClients() function is not returned as like below
>> log;
>> << Start of Log >>
>> Destination Gateway/Mask/Hw Flags Refs Use Expire
>> Interface
>> default 127.0.0.1 UGS 0 0 0 lo0
>> 127.0.0.1 127.0.0.1 UH 1 0 0 lo0
>> Create socket.
>> Bind socket.
>> Listen.
>> Accept.
>> << End of Log >>
>> Please could you let me know my fault ?
>> Best Regards.
URL: <http://lists.rtems.org/pipermail/users/attachments/20140519/9c69a3d8/attachment-0001.html>
