Time going backwards with clock_gettime(CLOCK_MONOTONIC, ...)
Nick Withers nick.withers at anu.edu.au
Thu Nov 13 00:54:31 UTC 2014
On Wed, 2014-11-12 at 07:19 +0100, Sebastian Huber wrote:
> On 12/11/14 02:41, Nick Withers wrote:
> > On Tue, 2014-11-11 at 07:53 +0100, Sebastian Huber wrote:
> >> >Hello Nick,
> >> >what is the output of the spnsext01 test for this BSP/board?
> > Hrmm, doesn't look good:
> > ____
> > *** BEGIN OF TEST SPNSEXT 1 ***
> > ../../../../../../../../rtems/c/src/../../testsuites/sptests/spnsext01/init.c: 66 !_Timespec_Less_than(&new_uptime, &uptime)
> > ____
> > ...followed by a reset.
> This shows that the nanoseconds extensions of the clock driver is broken.  This
> explains also your time going backwards problem.
So I should look at the routine installed by
rtems_clock_set_nanoseconds_extension() for my BSP?
In the case of the MVME3100, that seems to be
Clock_driver_nanoseconds_since_last_tick() in
c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c
(I'm not totally sure if it's meant to be, since the BSP's Makefile.am
seems to refer to e500/clock.rel rather than e.g., the MVME5500's
mpc6xx/clock.rel, but I know nothing 'bout autotools!).
Thanks for your help, any suggestions appreciated as I'm really going to
want to fix this...
Nick Withers
Embedded Systems Programmer
Department of Nuclear Physics, Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
