How to add a directory in rtems-src?
Ben Gras beng at shrike-systems.com
Fri Nov 7 15:13:26 UTC 2014
All,
Indeed, if you have a .exe ready, there is a script you can use to include
that with uboot to get a bootable sd card. To see how to use one of the
example .exe's to do this is a good test to see if your setup is OK before
trying custom code. To see all the steps for that:
http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
Good luck!
On Fri, Nov 7, 2014 at 1:32 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> How
> On November 4, 2014 9:34:21 PM CST, "黄喜" <huangxi_hans at 163.com> wrote:
> >Hello  Joel ,
> >        Very lucky send a mail to you.
> >I download the RTEMS4.11 source code from git and compile it Ok for
> >BeagleBoneBlack port. And then, I want to write the application code, I
> >want to create a directory 'application ' in rtems-src directory, and
> >put some directory in or .h or .c files in  application directory. It
> >maybe modify some Makefiles or configure files, So I want to know the
> >details to tell me how to do it. Thank you very much.
> You need to ask this on the users@ or devel@ mailing list.
> In general, the examples-v2 repo shows how to make an application exe
> using simple Makefiles or WAF (nicer) as the build system. But the Beagle
> has steps past that to get the exe into the right format and onto bootable
> media.
> Best to discuss this on list.
> >       Best Regards.
> >                   Hans.
> >At 2014-11-03 18:00:26, users-request at rtems.org wrote: >Send users
> >mailing list submissions to >  users at rtems.org > >To subscribe or
> >unsubscribe via the World Wide Web, visit
> >>      http://lists.rtems.org/mailman/listinfo/users >or, via email,
> send a
> >message with subject or body 'help' to >       users-request at rtems.org >
> >You
> >can reach the person managing the list at >    users-owner at rtems.org >
> >>When replying, please edit your Subject line so it is more specific
> >>than "Re: Contents of users digest..." > > >Today's Topics: > > 1. Re:
> >Re: The error in building rtems source about stm32f4 bsp >
> >(ZhangZhenxing) > 2. RTEMS Run-time Linker vs Linux dynamic linking
> >with shared > library. (Thomas Kim) > >
> >> >Message: 1 >Date: Thu, 30 Oct 2014 22:38:15 +0800 >From:
> >ZhangZhenxing <harbor0727 at gmail.com> >To: "Joel Sherrill"
> ><joel.sherrill at oarcorp.com>, "Chris Nott" >    <chrisn at vl.com.au>, users
> ><users at rtems.org> >Subject: Re: Re: The error in building rtems source
> >about stm32f4 bsp >Message-ID: <201410302238127869601 at gmail.com>
> >>Content-Type: text/plain; charset="utf-8" > > >On 10/29/2014 11:19 AM,
> >Chris Nott wrote: >> On 29/10/2014 8:05 AM, Joel Sherrill wrote: >>>
> >Sure. Hopefully Chris Nott will just reply to this thread when he >>>
> >spots it. :) >> Quite correct, I missed a file. This patch should
> >resolve it. >Patch is merged. > >Thanks. > >--joel >>> On 10/29/2014
> >9:59 AM, ZhangZhenxing wrote: >>>> Thank you very much! >>>> can I
> >receive the notice about the error if it is resolved? >>>>
> >>>>> harbor0727 at gmail.com >>>> >>>> *From:* Joel Sherrill
> ><mailto:joel.sherrill at oarcorp.com> >>>> *Date:* 2014-10-29 22:40 >>>>
> >*To:* ZhangZhenxing <mailto:harbor0727 at gmail.com>; users >>>>
> ><mailto:users at rtems.org>; Chris Nott <mailto:chrisn at vl.com.au> >>>>
> >*Subject:* Re: The error in building rtems source about stm32f4 bsp
> >>>>> >>>> On 10/29/2014 9:07 AM, ZhangZhenxing wrote: >>>>> Hi, >>>>> I
> >got the rtems source builder by the git command("git clone >>>>>
> >git://git.rtems.org/rtems-source-builder.git") and builded rtems >>>>>
> >4.11 toolschain by rtems source builder with the configure >>>>>
> >command("../rtems-4.10.99/configure --target=arm-rtems4.11 >>>>>
> >--enable-posix --enable-networking --enable-cxx >>>>>
> >--enable-rtemsbsp=stm32f4 --prefix=/opt/rtems-4.11/"). Then, when >>>>>
> >executing "sudo make all install" after "./configure", there is a >>>>>
> >error as follow. Why is it? How can I do for it? Thank you very >>>>>
> >much! >>>>> >>>> I can confirm that I got the same message in a full
> >build I ran >>>> Oct 26 but just now got a >>>> chance to look at.
> >Using git blame, I see it was the last patch >>>> from Chris Nott[1].
> >It looks >>>> like the patch added some files to the Makefile.am but
> >didn't >>>> include them. >>>> >>>> Chris.. if you can submit a patch
> >which adds the new files, I will >>>> merge it quickly. At the >>>>
> >moment, no stm32f*is building. >>>> >>>>
> http://git.rtems.org/rtems/commit/?id=040ed0b4cdd1c663408664ba3a8b2e5de0cf54e0
> >>>>> >>>> You could locally revert that patch and continue until it is
> >>>>> resolved in the master. This is >>>> just part of using the
> >development head. 99% of the time it is OK >>>> but once in a while,
> >>>>> it isn't. >>>> >>>> [1] Sorry I missed having lunch or dinner with
> >you. :) >>>>> make[8]: Entering directory >>>>>
> >`/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp/arm/stm32f4'
> >>>>>> /usr/bin/install -c -m 644 >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/bsp_specs
> >>>>>> ../../../../../.././stm32f4/lib/bsp_specs >>>>> /usr/bin/install
> >-c -m 644 >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/tm27.h
> >>>>>> ../../../../../.././stm32f4/lib/include/tm27.h >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/bsp.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp.h >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/coverhd.h
> >>>>>> ../../../../../.././stm32f4/lib/include/coverhd.h >>>>>
> >/usr/bin/install -c -m 644 include/bspopts.h >>>>>
> >../../../../../.././stm32f4/lib/include/bspopts.h >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/bootcard.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp/bootcard.h >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/utility.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp/utility.h >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/irq-generic.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp/irq-generic.h >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/irq-info.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp/irq-info.h >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../../shared/include/stackalloc.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp/stackalloc.h >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../shared/include/start.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp/start.h >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/../shared/armv7m/include/armv7m-irq.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp/armv7m-irq.h >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/irq.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp/irq.h >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/usart.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp/usart.h >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp/stm32f4.h >>>>>
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_gpio.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_gpio.h
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_rcc.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_rcc.h
> >../../../../../../../../rtems-source-code/c/src/lib/libbsp/arm/stm32f4/include/stm32f10xxx_exti.h
> >>>>>> ../../../../../.././stm32f4/lib/include/bsp/stm32f10xxx_exti.h
> >>>>>> make[8]: *** No rule to make target `include/stm32f4xxxx_adc.h',
> >>>>>> needed by >>>>>
> >`../../../../../.././stm32f4/lib/include/bsp/stm32f4xxxx_adc.h'. >>>>>
> >Stop. >>>>> make[8]: Leaving directory >>>>>
> >>>>>> make[7]: *** [preinstall-recursive] Error 1 >>>>> make[7]:
> >`/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp/arm'
> >>>>>> make[6]: *** [preinstall-recursive] Error 1 >>>>> make[6]:
> >`/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib/libbsp'
> >>>>>> make[5]: *** [preinstall-recursive] Error 1 >>>>> make[5]:
> >`/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4/lib'
> >>>>>> make[4]: *** [preinstall-recursive] Error 1 >>>>> make[4]:
> >`/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c/stm32f4' >>>>>
> >make[3]: *** [preinstall-stamp] Error 2 >>>>> make[3]: Leaving
> >directory >>>>>
> >make[2]: *** [all-recursive] Error 1 >>>>> make[2]: Leaving directory
> >>>>>> make[1]: *** [all-recursive] Error 1 >>>>> make[1]: Leaving
> >directory >>>>> `/home/zhangzhenxing/rtems/build-rtems/arm-rtems4.11/c'
> >>>>>> make: *** [all-recursive] Error 1 >>>>> >>>>>
> >>>>>> >>>>> harbor0727 at gmail.com >>>> -- Joel Sherrill, Ph.D. Director
> >of Research & >>>> Development >>>> joel.sherrill at OARcorp.com On-Line
> >Applications Research >>>> Ask me about RTEMS: a free RTOS Huntsville
> >AL 35805 >>>> Support Available (256) 722-9985 >>>> >>> > >-- >Joel
> >Sherrill, Ph.D. Director of Research & Development
> >>joel.sherrill at OARcorp.com On-Line Applications Research >Ask me about
> >RTEMS: a free RTOS Huntsville AL 35805 >Support Available (256)
> >722-9985 > >-------------- next part -------------- >An HTML attachment
> >was scrubbed... >URL:
> http://lists.rtems.org/pipermail/users/attachments/20141030/4ebcaf11/attachment-0001.html
> >> >------------------------------ > >Message: 2 >Date: Mon, 3 Nov 2014
> >19:00:21 +0900 >From: Thomas Kim <thomas73.kim at gmail.com> >To:
> >"rtems-users at rtems.org" <users at rtems.org> >Subject: RTEMS Run-time
> >Linker vs Linux dynamic linking with shared >  library. >Message-ID:
> >>      <CADY8aTBTKXBNuKrKfWSyDM2eBMq7ocLhZwBgo+43pqKb2V=
> 2Rg at mail.gmail.com>
> >>Content-Type: text/plain; charset="utf-8" > >Dear Sir, > >I checked
> >that RTEMS runtime linker was updated on main tree. > >I would like to
> >know something before testing RTEMS run-time linker. > >I am guessing
> >that RTEMS run-time linker is different with linux dynamic >linking
> >with shared library(*.so.*). > >I hope that RTEMS run-time linker is
> >same concept with Linux dynamic >linking with shared library. > >Please
> >advise me. > >Best Regards. >-------------- next part --------------
> >>An HTML attachment was scrubbed... >URL:
> http://lists.rtems.org/pipermail/users/attachments/20141103/39e94d26/attachment.html
> >> >------------------------------ > >Subject: Digest Footer >
> >>_______________________________________________ >users mailing list
> >>users at rtems.org >http://lists.rtems.org/mailman/listinfo/users >
> >>------------------------------ > >End of users Digest, Vol 98, Issue 1
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20141107/933c2cd5/attachment-0002.html>
