Time going backwards with clock_gettime(CLOCK_MONOTONIC, ...)
    Nick Withers
    nick.withers at anu.edu.au
    Wed Nov 12 01:41:42 UTC 2014
On Tue, 2014-11-11 at 07:53 +0100, Sebastian Huber wrote:
> Hello Nick,
> what is the output of the spnsext01 test for this BSP/board?
Hrmm, doesn't look good:
____
*** BEGIN OF TEST SPNSEXT 1 ***
../../../../../../../../rtems/c/src/../../testsuites/sptests/spnsext01/init.c: 66 !_Timespec_Less_than(&new_uptime, &uptime)
____
...followed by a reset.
Nick Withers
Embedded Systems Programmer
Department of Nuclear Physics, Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
> On 11/11/14 03:40, Nick Withers wrote:
> > Hullo all!
> > I've seen successive calls to clock_gettime(CLOCK_MONOTONIC, ...) return
> > earlier times (RTEMS 4.11 on the MVME3100 PowerPC BSP) and have whacked
> > a test case together (see attached) which just busy loops calling it.
> > Example failures:
> > ____
> > Starting...
> > Time went backwards, from {0, 59999000} to {0, 50000000}
> > Time went backwards, from {0, 559999000} to {0, 550000000}
> > Time went backwards, from {0, 849999000} to {0, 840000000}
> > Time went backwards, from {1, 9999000} to {1, 0}
> > Time went backwards, from {1, 39999000} to {1, 30000000}
> > Time went backwards, from {1, 249999000} to {1, 240000000}
> > Time went backwards, from {1, 299999000} to {1, 290000000}
> > Time went backwards, from {1, 319999000} to {1, 310000000}
> > Time went backwards, from {1, 359999000} to {1, 350000000}
> > Time went backwards, from {1, 829999000} to {1, 820000000}
> > ____
> > Could this be related to bug 1748 (can't see it right now with rtems.org
> > down)? Any other ideas where I should look to fix this, or whether it's
> > a known thing?
> > Ta all!
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
