RTEMS shell, classic API required?
Hoefle Marco Marco.Hoefle at nanotronic.ch
Thu Oct 2 08:44:00 UTC 2014
Hello Sebastian,
that did the trick, thanks. RTEMS shell is now working.
Getcwd seems also not to work there. We investigate this further.
Marco
-----Original Message-----
From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
Sent: Donnerstag, 2. Oktober 2014 10:10
To: Hoefle Marco; rtems-users at rtems.org
Subject: Re: RTEMS shell, classic API required?
On 02/10/14 10:05, Hoefle Marco wrote:
> On the console we see:
>   starting shell
> pthread_setspecific(shell_current_env_key)
> sc: 0, errno: Success
You should read the release notes.  A lot changed between the RTEMS 4.10
release and the current Git master.
For the RTEMS shell you have to configure some POSIX keys.  For an easy start use:
#define CONFIGURE_UNIFIED_WORK_AREAS
#define CONFIGURE_UNLIMITED_OBJECTS
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
