Bug in getcwd()
Rohner Thomas Thomas.Rohner at nanotronic.ch
Thu Oct 2 10:11:15 UTC 2014
Hello,
> We have a system with the following configuration.
> Platform:
> ·Chip GR712RC
> ·Board: GR712 Development Board
> ·Compiler RTEMS RCC (according to your websites version)
> ·RTOS: RTEMS
> ·Library: GR-RTEMS-DRIVER Version 1.2.1.0
I'm using FAT as filesystem. We have same phenomenon for FAT12 or FAT16!
Freundliche Grüsse / Kind regards,
Thomas Rohner
Entwicklungsingenieur Software
nanoTRONIC GmbH
Werkstrasse 27, CH - 3250 Lyss
T: +41 32 384 69 30, F: +41 32 384 69 31
www.nanotronic.ch <http://www.nanotronic.ch/>  | thomas.rohner at nanotronic.ch
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: Mittwoch, 1. Oktober 2014 20:11
To: Rohner Thomas; rtems-users at rtems.org
Subject: Re: Bug in getcwd()
On 10/1/2014 9:26 AM, Rohner Thomas wrote:
	Hello,
	maybe I found a bug in getcwd().
	We're using RTEMS 4.0 with Gaisler-Aeroflex....
	With our libraries I get an erroneous string when directory-depth is about 4 folders from root!
	When I use this string to read directory it crahes!
	Is there a limitation of string-length?
	I get the same results for
	               Char buffer[200];
	getcwd(buffer,sizeof(buffer));
	or
	               char* ret = getcwd(NULL,0);
Is this with the IMFS? What BSP?
Can you put together a full test example so we can
see what is really happening?
There is a POSIX constant for PATH_MAX as I recall but
it is quite large.
Thomas Rohner
nanoTRONIC GmbH
URL: <http://lists.rtems.org/pipermail/users/attachments/20141002/aa3453ea/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.rtems.org/pipermail/users/attachments/20141002/aa3453ea/attachment-0001.jpg>
