rtems hello world, doesn't hit POSIX_init
Sat Oct 4 15:18:40 UTC 2014
On October 4, 2014 10:02:49 AM CDT, Gedare Bloom <gedare at rtems.org> wrote:
>On Fri, Oct 3, 2014 at 11:43 PM, Joel Sherrill
><joel.sherrill at oarcorp.com> wrote:
>> On October 3, 2014 9:18:45 PM CDT, Gedare Bloom <gedare at rtems.org>
>wrote:
>>>On Fri, Oct 3, 2014 at 10:03 PM, alrik <alrik at utopiacompression.com>
>>>wrote:
>>>> Hey all,
>>>> I'm new to using rtems (and rtos'es in general), so apologies if my
>>>question
>>>> covers well-tread ground.
>>>Welcome!
>>>> I have a minimal, hello world type of main.cpp -- I use POSIX_Init
>as
>>>my
>>>> entry point, do a printf, then exit. I also am compiling a
>separate,
>>>large
>>>> code base and linking it into the executable, but I am not
>including
>>>any
>>>> files from it or calling any of the functions from there in my main
>>>file.
>>>> When I run my application, it doesn't seem to ever hit my
>POSIX_Init
>>>entry
>>>> point -- I don't see my printf call, and if I run it in a debugger
>>>and look
>>>> at the backtrace after it has completed, I get the following --
>>>It's possible the printf simply never showed up before the board
>>>resets. What target (BSP) are you using?
>>>If you can set breakpoints with the debugger, you may want to place
>>>one in POSIX_Init.
>>>> moviDebug: INFO: IP = 70181110, , crt0.S, 338.
>>>> moviDebug: INFO: IP = 7018B66C, _User_extensions_Iterate at 0x3C,
>>>> userextiterate.c, 155.
>>>> moviDebug: INFO: IP = 70188DF8, _Terminate at 0x20, userextimpl.h,
>245.
>>>> moviDebug: INFO: IP = 701985C0, rtems_gxx_mutex_init at 0x38,
>>>gxx_wrappers.c,
>>>> 178.
>>>> moviDebug: INFO: IP = 70192FB4,
>>>> _GLOBAL__sub_I___cxa_allocate_exception at 0x18, concurrence.h, 135.
>>>> moviDebug: INFO: IP = 70199504, , pthreadself.c, 32.
>>>> moviDebug: INFO: IP = 7019A7FC, , pthreadself.c, 32.
>>>> moviDebug: INFO: IP = 70190DD0, _Thread_Handler at 0xF8,
>>>threadhandler.c, 181.
>>>> moviDebug: INFO: IP = 70190CD8, _Thread_Handler at 0x0,
>threadhandler.c,
>>>89.
>>>> moviDebug: INFO: IP = CDCDCDCD, , pthreadself.c, 32.
>>>> moviDebug: INFO: IP = ADADADAD, , pthreadself.c, 32.
>>>> moviDebug: INFO: IP = 0, , confdefs.h, 68.
>>>> I'm at a bit of a loss as to why this could be the case; I can run
>>>this same
>>>> rtems/posix 'hello world' correctly when I'm not linking to the
>>>separate,
>>>> large code base, but since I'm not including or calling any of that
>>>code's
>>>> files or functions, how can it be having this effect (i.e. my
>>>program's
>>>> inability to get to the entry function)?
>>>That "cxa_allocate_exception" is certainly suspicious to me. I don't
>>>use C++ enough to know, but that backtrace kind of looks like a mutex
>>>failed to initialize due to out-of-memory. Perhaps the memory is
>>>exhausted? How much memory is available? How big is the executable?
>>>You can use rtems4.11-arch-size to get the size of the linked binary.
>>>Compare that to the memory available in the platform. You can run
>>>spsize to get an idea of the runtime overhead to get base RTEMS up.
>> More likely not out of memory but not accounting for the resources
>used. Probably easier to configure with unlimited objects to make it
>work.
>Maybe, although why would the version without linking against the
>other code base work?
>It would be helpful to see the main.cpp and RTEMS_CONFIGURE_X macros
>that are used, if possible.
There is a default configuration with an Init. I don't recall what it does exactly but it probably doesn't include resources for C++. Maybe not even POSIX objects. And it provides its own Init()
We need to see the entire main.cpp
>-Gedare
>>>-Gedare
>>>> Thanks,
>>>> Alrik
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
>>>users mailing list
>>>users at rtems.org
