RTEMS crash with mem address not aligned failure
Jiri Gaisler jiri at gaisler.se
Mon Oct 6 15:09:24 UTC 2014
On 10/06/2014 04:45 PM, Joel Sherrill wrote:
> On 10/6/2014 2:03 AM, Chris Johns wrote:
>> On 6/10/2014 5:08 pm, Sebastian Huber wrote:
>>> On 04/10/14 07:07, Chris Johns wrote:
>>>>>> Could this be a newlib issue? We are using:
>>>>> Is the memory map ok for the BSP ? It pays when moving to 4.11 from 4.10
>>>>> to check the memory map is ok.
>>>> I can confirm this happens on the SIS bsp in simulator using the
>>>> fileio.exe
>>>> example. Run the sample, hit a key, start the shell and enter ls.
>>> I don't see this problem here.  I use sparc-rtems4.11-gcc 4.9.2 20140924
>>> with the latest Newlib.
>> Do you see it with the RSB tools ?
> I have the RSB tools and it doesn't crash for me on sis. I also noticed
> that in the report, there is a hello command which is not part
> of the standard command set.  I wonder if that command or
> how it was added is triggering something.
> This may not be the latest but this is what I have installed.
> $ sparc-rtems4.11-gcc --version
> sparc-rtems4.11-gcc (GCC) 4.8.3 20140522 (RTEMS
> 4.11-RSB-257d1e4378c80968de57ba888e235888adb0e992-1,gcc-4.8.3/newlib-19-Aug-2014)
It does crash on sis for me, using RSB from some months ago:
sparc-rtems4.11-gcc (GCC) 4.8.2 20131016 (RTEMS 4.11-RSB-527515c38007b0614a2cafed863190438e8375bc-1,gcc-4.8.2/newlib-2.1.0)
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Jiri.
> Do I need to build something newer?
>> Chris
>> users mailing list
>> users at rtems.org
