Is anyone running RTEMS on an Adlink cPCI-6615 board?
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Oct 6 20:20:35 UTC 2014
On 10/6/2014 3:11 PM, Rick Lellinger wrote:
> Hi
> We are evaluating this board as a candidate for a replacement CPU
> board on crates that are presently running RTEMS. The CPU is a
> dual-core ATOM D525. The standard RTEMS distribution shows support for
> the Ethernet chip ( 82853V). Any additional info, tips or tweaks for
> RTEMS on the '6615 would be greatly appreciated.
It sounds like it is just a PC in a different form factor. It should be
able to
boot a standard pc386 BSP executable although you likely want to use
a variant built using gcc CFLAGS optimized for the specific CPU core.
Beyond that, I would assume the standard PCI interface code would just
work.
> Rick Lellinger
> Lawrence Berkeley National Laboratory
URL: <http://lists.rtems.org/pipermail/users/attachments/20141006/387e1179/attachment.html>
